The Sportster and Buell Motorcycle Forum - The XLFORUMģ
Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUMģ > GENERAL AREA > Off-Topic/General Discussion
0 Allegheny National Park III
Last Post: paulc
0 Rear Brake Squeal Fixed
0 Rocker Arm Acorn Nut Torque Problems..
Last Post: Flam
0 Informed reviews!
0 R.I.P.Meat Loaf
Last Post: deguireb
0 my motorcycle trailer (goes down flat, comes back up)
Last Post: adri
0 1980 Shovelhead WideGlide
0 Speedometer
0 Primary thread
Last Post: RandallM
0 weight loss thread
0 Dyno Test Results: W Cams versus D Cams
Last Post: Jonny48
0 2022 Sportsters
Last Post: Edster
0 LED Smoked Turn Signals (Arlen Ness & Custom Dynamics)
Last Post: cbzdel
Last Post: wrkdWS6
0 Video - Dyno Numbers are NOT What We Look For!
0 1995 Manual
Reynoldston (81), showmebandit (68), Hoppy1313 (68), FredrikK (66), Toejam503 (66), YO MUDA (63), Altopass (62), tim 2007xl1200c (55), w9awx (49), 3xtrastout (43)
  #511
Old 12th November 2021
Kelley, you getting any riding in after the “great flood”?
Pleasing everyone is impossible but pissing everybody off is a piece of cake!
Old 17th November 2021
Crusty Crusty is online now
Sportster/Buell Year: 2016
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XL 1200 C
Perplexing Problems
My bike is ill and Iím not sure what the problem is.
It started tapping on the way home from Canton. I figured it was a bad tappet (lifter) and I thought it was coming from the front cylinder. So I changed out both of the lifters, which turned out to be a royal PITA job. When I was done, I started the bike and it was quiet; the tapping was gone.
When I took the bike out the next day, the noise returned when the bike warmed up. My problem is that I canít determine whatís causing it. Rather than continuing to throw parts at the engine, I went to an independent shop yesterday and had them listen to it. The noise was evident, but the source is not. Even three people who work on Harleys for a living, using an electronic mechanicís stethoscope, were unable to positively identify the source of the ticking/knocking.
While I feel a bit better about my abilities as a mechanic,it still doesnít help me solve my problem. So; after talking with the shop owner, Iíve decided to change out the lifters for the rear cylinder. There are reasons for this decision; the noise was a little louder toward the back of the engine when they listened with the scope, and I still feel itís a lifter noise. Iím also going to spend a bit extra and change out the pushrod tubes for a set of old style tubes. That way, if I ever have to go back and change out another lifter, I wonít have to take the head off. Itíll be a bit more work to do that now, but it will save time in the future if I ever need to do it again. And itís the way the bike should have come from the factory. I want to make the Gentlemanís Express the Best Sportster it can be in spite of the bean counters.
One thing that was recommended was to install a set of Rocker Lockers. I hadnít heard of these before, but they make sense. If youíre mechanical and also havenít heard of them, go to:
https://www.dkcustomproducts.com/spo...-dk-rl-spt.htm
They may be snake oil, but they don't cost a lot. I think they wonít hurt anything and just might help.
So in a little while, Iíll head over to Cin City H-D and buy some gaskets and lifters. My pushrod tubes should be in this afternoon. I donít know how long itíll be to get the Rocker Lockers, but theyíll be going in towards the end of the job, so Iím not too worried.
I WILL get the Express running right. Itís looking really good, now I want it to be running really good.
Old 23rd November 2021
The Hour of The Wolf
Iím wide awake and my head is racing. My bike is still making ugly noises, but I now have an idea of what the problem is.
Yesterday, I called Guido at the shop and had a detailed conversation with him. When I first told him about the noise, he said lifters. I told him that Iíd changed all four and he said, ďYouíre f**kedĒ. (Dondi told me that he really is a good friend if heís willing to talk like that to me.)
As I described when it was loudest and when it quieted down, he said itís piston slap; I was describing classic symptoms. That makes the most sense to me. If it was a rod bearing, it would be pretty constant. So I looked up parts on Ronnieís parts finder and saw that the MoFoCo offers piston and cylinder assemblies. So I guess Iíll be changing out both front and rear pistons and cylinders. I figure that if I change out just the front, itíll turn out to be the rear that was bad and vice versa. And if itís only one thatís bad, and I guess right, then the other piston will start making noise in short order and Iíll have to rip the bike down again.
The thing thatís preying on my mind this morning is why did the piston fail? The pistons should be good for at least 100,000 miles. My fear is that Iíll do the top end and the problem will resurface a few thousand miles down the road. Was it just a fluke or is there some underlying problem that caused the failure? If there is something that needs to be addressed, can I do it in my tiny 3/4 car garage, or will I have to find a shop that can fix it right? And how much will it cost? Well; Iíll give it a bit more thought; I want the Express to carry me to the Arctic Ocean and back without trouble. This has been my dream bike and I want it to be right.
Well; itís after three AM. I think Iíll put some Strauss on the Wave and let the Blue Danube carry me off to hopefully peaceful dreams.
Old 1st December 2021
Excitement!
My life isn’t boring; that’s a good thing. Every time it starts to get “Routine”, something happens to spark things up. Sometimes, I’m the cause; but most times it’s just the way my life is. To be fair; not all the exciting things are good things. Some of them have been pretty rough, but there have been many positive things that have happened, as well. You can’t have the one without the other.
Two days from this moment, I’ll be on a plane heading for Boston. I cut a deal with the shop. I’d say that I cut a deal with Guido; but his two kids, Sandra and Guy were also involved. I’m getting a 2006 XL 1200C. I’m flying into Logan Airport, taking subways and a bus to the shop, then I’ll be riding back to Cheviot.
It’s going to be a cold ride home; but I’m bringing my electric jacket liner and my thermal undies. I plan to take a couple of days, so it shouldn’t be too bad. My feeling is that if Dave Barr could ride a Sportster across Siberia in the winter, then I can ride from Boston to Cincinnati in December.
I informed Sandra of my itinerary, and she said that they would be getting pizza from the Bridge Cafe for lunch. I’m going to the land of Great Pizza once again, and I intend on eating my fill. I also plan to get a box of Kayem Natural Casing Franks and carry them back, as well. Since the temps are going to be on the cold side, they’ll last just fine.
Not only is my life not boring, but I’m extremely fortunate in having the friends that I do. I've already had one friend offer to give me a set of mid- controls for the bike, as well as a pair of stock mufflers, if the bike is too loud for me. I don’t like loud pipes on long rides. They ruin my ability to hear.
Another friend has offered to drive out to Cheviot with a trailer and haul me and the Express to his house, where we can tear down the Express and send the crank to Dark Horse Crankworks and get the crankshaft rebuilt with all first class components, and balanced and trued and welded the way it should come from the factory. The crank is a good design, it’s the bean counters who are saving a few cents here and there that are causing the problems, in my very strong opinion. I bet the parts that failed were made only with the most mediocre Chineseium components available. Their mindset is something like, “The average owner only puts a couple of thousand miles on the bike a year, so if the cranks fail at 20,000 miles, then that’s ten years from now and the warranty will have expired long ago. And we get to save $0.67 cents, Net! Besides; it’s only a starter bike; what they really want is a Big Twin Ultra!”
Other friends that I have do things like put me up whenever I’m in Massachusetts, or who’ll drive 100 miles just to give me a ride home from the hospital, or pay for my camping when I go to Georgia, or gave me a motorcycle when I was recovering from having my ankle crushed, or sent me a laptop without warning, or make brackets for my motorcycles, or… I could go on a lot longer.
I’m extremely fortunate to have such people in my life. I really do have a Blessed life.
And I’m getting another motorcycle!
sprink's Avatar
sprink sprink is offline
Sportster/Buell Model: 2004 XL1200R
Sportster/Buell Year: SOLD
Sportster/Buell Model #2: 2000 X-1 lightning
Sportster/Buell Year #2: SOLD
Other Motorcycle Model: XB1200XT "Uly"
Other Motorcycle Year: 2009
sprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond repute
Glad to hear it's working out! Safe travels.
ChinCactus's Avatar
Sounds like another happy ending! Ride on Crusty!
spoon spoon is offline
Other Motorcycle Model: KLR 650
Other Motorcycle Year: 1987
spoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant future
And pray tell how did a bad crank come into the picture? Did I (we) miss something?
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Other Motorcycle Model: FXDC
"And I’m getting another motorcycle!"
Blessed
Steve
'01 Cyclone
'13 FXDC 96" stock
+1 How did we go from piston slap to needing a crank?
Is it torn down or is this just speculation?
I pulled the top end off and the front rod moves like a joystick. I can also feel the big end bearings and they feel crunchy when the rod moves from side to side in an arc.
The previous Snippet was written a week ago. A lot happened during that week, including me tearing the engine down. I just wasn't up for sharing a lot and had no desire to write a Snippet about what was happening.
Now; things are happening so fast that I can't keep up with it all.
XL Forumģ - Linson Media LLC
