0 Front brake calliper strange noise...
Last Post: orvitarius
0 Frame bracket
0 Best Tuner options?
0 Fuel tank urns
Last Post: ezmerf
0 Happy Birthday Mrs. Folkie.
0 Hi from Barcelona!
0 top end noise
Last Post: jacsul
0 How tricky is it to replace dipstick trim from oil tank?
6 SPORTY BOBBER PICTURES
Last Post: Bryan83taco
0 Poll: Hwy Pegs: fwd mount or crash bar mount?
Last Post: oupa
0 su carb question
Last Post: Serious Blac
0 Buell special
0 how do eat an elephant,,
Last Post: cazz1000
0 Clutch lever pull effort
Last Post: Centennial Sportster
0 Psychedelic '70s SPortster Chopper Pictures
0 What engine oil do you use?
Last Post: TUCCI
0 Too HOT to ride?
Last Post: PetesPonies
Last Post: burely
0 Another clutch Question
Last Post: wrkdWS6
0 CV Carb - Transfer Ports
2003, 883, backfire, no start
Old 31st October 2012
rejeanprimeau's Avatar
Just tight up your choke plastic nut in the back of the knob; the choke will stay open completly. Go easy on the plastic nut, it's fragile.
Old 1st November 2012
spoon spoon is offline
Other Motorcycle Model: KLR 650
Other Motorcycle Year: 1987
spoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant futurespoon has a brilliant future
When I changed the vacuum hose to the VOES the VOES cracked. Vacuum leak. I would check the ignition switch. Put a meter on it and do a good juggle test. You may not be getting good contact at start time. I don't think this is the problem but if you have a tach you should look at the multi pin connector behind the headlight.corrosion on the pins will cause a no voltage to the ignition module. But I would think this would show up going down the road, hot or cold. Keep looking.
Old 2nd March 2013
sslnight sslnight is offline
sslnight is an unknown quantity at this point
I finally got to replace my ignition module and this has fixed my main issue. The bike still has issues with carb farts and lack of power (dead spot) at WOT but that is just a rejetting/tuning issue. Thanks for all of the help and i hope future people also benefit from this post. Now on to riding and tuning!
Old 3rd March 2013
sportsterdoc's Avatar
That was the most likely possibility, back in Oct. Glad you found it.
What is your present jetting?
