Last Post: CCC
Last Post: AKL1
0 Sportster Sport 1200S '98-'03 Ignition Replacement
Last Post: CCC
Last Post: webman94
0 1979 xlh brake pedal woes
Last Post: 1200CustomHD
0 Hurricanes
0 2013 48 what would you update first?
0 Hello from Home of HD
0 What Marker Lights Are These?
Last Post: FiftySixer
0 Post your paint questions here!!!!!
0 Turbo Iron 883
Last Post: Cj_
Last Post: duffy
0 Wanted
Last Post: maltesefalcon
0 KR style bolt on hard tail for 78 XLCH
Last Post: DirtyHarry68
Last Post: Diogenes415
0 13" Harley Take Off Air Shocks - $90
Last Post: mrbreezeet1
0 Progressive Suspension 412-4055C Chrome, 13" Heavy Duty springs, Rear
DaddyJay, sixshooter (73), cartoad2001 (71), Dirty Ernie (65), ncpickman (59), bri1200c (57), pquirk (54), GOTWA (51), gremlinsteve (51), lbowles2 (49), Guess (41), rnaway22es, landon283 (32)
Old 9th August 2020
small block chevy is 4'' bore.
Old 10th August 2020
Staffords Staffords is offline
Sportster/Buell Year: 1961
Other Motorcycle Model: FXE
Other Motorcycle Year: 1976
Staffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the rough
I decided for $30 I might as well snatch up a set of these: https://www.ebay.com/itm/New-TRW-Pow...edirect=mobile
Nitro57xl Nitro57xl is offline
Nitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of light
I think that's a smoking deal for a set of new pistons! Get some new repop cylinders to go with them since they are standard bore. I hope you don't still think these rare 9.22 to 1? They are not. But they will run good and you will like them As long as you run good gas in it?
9.22 to 1 is what the spec sheet says. I have a set of the more common 17550 TRW forged pistons 9:1 that I will compare (height and dome) against. I'm building a 61 CH and I'm not planning on dual plugging my heads, so if they're really much higher CR I probably won't run them.
if the domes are taller on these you could remove some material 'til they matched?
