0 NOS cases
Last Post: Yellowstone Kelly
Last Post: d10221
0 Ironhead engine problem?
0 72 ih stroker advise needed
Last Post: toe
Last Post: toe
0 WTB S&S super B parts
Last Post: bretton
Last Post: gl90hog
0 North central Mass
3 Wtb, Wts, Wtt, Wtg (Buells)
3 Wtb, Wts, Wtt, Wtg (XRs)
3 Wtb, Wts, Wtt, Wtg (EFIs)
3 Wtb, Wts, Wtt, Wtg (Evos)
0 BEWARE Of SCAMMERS!
0 Showa 54000088 Shocks
Last Post: d10221
Last Post: JimVonBaden
Old 23rd July 2021
XL_1200C's Avatar
XL_1200C XL_1200C is offline
XL_1200C has disabled reputation
Arrow Missing hand control screws
while working on the hand controls I saw that I had lost a couple of those special screws that Harley uses to hold the hand controls together, exactly one screw missing out of each hand control cluster. Is there a reasonable similar aftermarket screw source I can use to replace these with?
Thanks Again all for your pointers and info. It is much appreciated...
Slick...
05 XL1200C, NRHS AC, 42mm Mikuni, V&H 2 into1,12.5 Ricor shocks,TC88A-Jester VII map.
Old 23rd July 2021
wtwolf's Avatar
wtwolf wtwolf is offline
wtwolf is a splendid one to beholdwtwolf is a splendid one to beholdwtwolf is a splendid one to beholdwtwolf is a splendid one to beholdwtwolf is a splendid one to beholdwtwolf is a splendid one to beholdwtwolf is a splendid one to beholdwtwolf is a splendid one to beholdwtwolf is a splendid one to beholdwtwolf is a splendid one to beholdwtwolf is a splendid one to behold
i replaced mine with allen head bolts from the hardware store. they are a common thread i think 10-32
Old 24th July 2021
Yes, you can find replacement screws at most hardware stores, mine are getting replaced with stainless steel allenheads in place of the Torx head factory screws.
I.B.A.#26543,
Old 24th July 2021
Fivecats's Avatar
Fivecats Fivecats is offline
Sportster/Buell Year: '68
Sportster/Buell Model #2: FXR
Sportster/Buell Year #2: '89
Other Motorcycle Model: R50/5
Other Motorcycle Year: '73
Fivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond repute
AND be sure the correct torque is used when tightening them. Using the lower limit will work.
Old 24th July 2021
Fifty150's Avatar
Fifty150 Fifty150 is offline
Sportster/Buell Model: XL883L
Fifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant future
You can buy them from your local dealership. That's a part that they should have plenty of. I'm sure the techs in the service bay have a good supply of them. They are soft, and prone to damage. The heads are always getting damaged because people screw them down too tight, and then the next guy who has to remove them strips the heads trying to take them off.
The allen head screws are a good idea. Take the screw that you still have to the hardware store. Match the thread pitch and length. The dealership will probably want $5 for a screw and washer wrapped in a plastic bag, with a Harley logo on the label. Don't forget the washer.
Harley Davidson part number 42425-05
Old 24th July 2021
XL_1200C's Avatar
Thank You Guys!
Ill take care of those nasty screws today!
Lol, Slick
Old 25th July 2021
Andy56 Andy56 is offline
I have seen plenty of hex cap head screws rounded out.
What does for torx screws is people using the wrong size driver. Just look at the mess people get into using a T25 when it should be a T27.
Old 25th July 2021
Fifty150's Avatar
A lot of people buy kits which don't have T27. They just don't know. So they use T25. Odd that T27 is not in a lot of Torx kits.
Old 25th July 2021
The hand controls is made up of two parts and uses 2 different sizes of screw. The one pictured above #42425-05 is the larger size and is T27. The smaller one is HD part #3658 and is T25.
It is now very easy to see why someone would post about them getting rounded out - the wrong size driver was used by someone.
Old 25th July 2021
Folkie Folkie is offline
They're 10 - 24 UNC × ½". I replace them with stainless steel Allen screws.
I put button heads on the top, and regular capscrews on the bottom.
The original screws are Harley part no 3658.
