0 Crankcase drain
Last Post: Andy Hog
0 71 XLH Value?
Last Post: JimVonBaden
0 The Strociek Project
Last Post: tkvalentine
0 sportster revival
0 Q cams in 73 xlh ??
Last Post: 73HEAD
0 Posting Pics
Last Post: BigAl57
7 2001 xlh 1200 off road
Last Post: Warlock
0 Allegheny National Park III
Last Post: Elzer0
0 Japanese Cush Drive!!
0 Canadian Purchases
Old 25th July 2021
Andy56 Andy56 is offline
The original screws are Harley part no 3658.
You are assuming the screw was lost from the switch housing and not the lever housing. The OP didn't tell us.
Old 25th July 2021
Folkie Folkie is online now
You're right; I'm assuming he means the screws for the switch housing. I thought that's what he meant by 'hand control cluster'.
Old 25th July 2021
And you could be correct.
Irrespective it is vital that the driver be inserted fully before attempting to do up or undo whichever fastener type you go for.
I mentioned before I have seen plenty of hex head cap screws rounded out. Probably more so by using cheap drivers that are not quite the right size.
Old 25th July 2021
As for the brake and clutch lever perch clamp screws:
On 2004-5 they're:
# 4262: Screw, M6 X 1mm X 22mm
(no washer)
On 2006 onwards:
# 4535M: Screw, M6 X 1mm X 25* torx button head
# 6101: Washer, 27/64" X 17/64" X 1/16"
Kit # 42425-05 includes 2 × # 4535M and 2 × # 6101.
Edit:
*: Harley say it's T25, but it's actually T27!
Last edited by Folkie; 25th July 2021 at 15:27.. Reason: Corrected incorrect info from Harley
Old 25th July 2021
Originally Posted by Andy56 View Post
#42425-05 is the larger size and is T27.
# 4535M: Screw, M6 X 1mm X 25 torx button head
(# 4535M is the screw that is {supposedly?} in kit # 42425-05)
Hmmm, what gives?
Well, it seems that although the Harley Parts Catalogs (2006-9) say T25, it's actually a T27!
Old 26th July 2021
Isn’t this fun boys and girls?
I.B.A.#26543,
Old 26th July 2021
XL_1200C's Avatar
XL_1200C XL_1200C is offline
XL_1200C has disabled reputation
Arrow
Hi Yes, thank I should have been more clear. It is the switch housing screws that I meant.
I got back from Lowes a couple days ago with the right Allen head screws and we are all good now. I kept a couple of spares in the tool box too.
Thanks, Slick
05 XL1200C, NRHS AC, 42mm Mikuni, V&H 2 into1,12.5 Ricor shocks,TC88A-Jester VII map.
