0 NOS cases
Last Post: Yellowstone Kelly
Last Post: d10221
0 Ironhead engine problem?
0 72 ih stroker advise needed
Last Post: toe
Last Post: toe
0 WTB S&S super B parts
Last Post: bretton
Last Post: gl90hog
0 North central Mass
3 Wtb, Wts, Wtt, Wtg (Buells)
3 Wtb, Wts, Wtt, Wtg (XRs)
3 Wtb, Wts, Wtt, Wtg (EFIs)
3 Wtb, Wts, Wtt, Wtg (Evos)
0 BEWARE Of SCAMMERS!
0 Showa 54000088 Shocks
Last Post: d10221
Last Post: JimVonBaden
Old 25th July 2021
You should not vent the cap.
The Harley design is for the oil tank to vent back to the cam chest.
The tank vent is actual a pressure bypass, normally closed, not an open vent.
Old 25th July 2021
LenC's Avatar
LenC LenC is offline
Sportster/Buell Model: NRHS 1250
Other Motorcycle Model: Triumph Bonneville Black
Other Motorcycle Year: '06
LenC has disabled reputation
Originally Posted by Cablejudge View Post
Hi,
I have one of those: https://www.tolle-engineering.se/sto...-for-hd-437026
Not the cheapest version, and I am not sure if they are sold in the US at all? But they are very good.
I had to replace my standard gas cap because the speedo / tachometer came down when I installed the longer front forks (a custom, so the are below the handle bar) and it got really very, very tight between the instruments and the gas cap. I am very happy with it - but at least with the small version the knurled part is smaller when the standard cap, so I am not sure if this would be easier for you.
Brgds
Juergen
Phew!
Krona or dollars, they're quite proud of those!
Old 25th July 2021
LenC's Avatar
Originally Posted by zukinut View Post
I have the drag specialties unit. It works well. However the supplied O ring is garbage. I took the o ring off the original cap and put it on the pop up and all is well.
I don’t think I would recommend it for arthritic hands tho, it can sometimes be a bear to get off.
Thanks for pointing that out!
Old 25th July 2021
LenC's Avatar
Marijuana's legal now where you are I see.
Gas tank, Hippy. Gas tank.
Old 25th July 2021
Maybe he has a new pressure/flow theory where the cam chest gets vented to the gas tank and then to the oil tank...
Old 25th July 2021
mick42's Avatar
mick42 mick42 is offline
Sportster/Buell Model: 1200Roadster
Other Motorcycle Model: BMW K1600GT
mick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond repute
I have had the Harley Davidson pop-up on my tank for about seven years. It was a PITA to get to pop up at first. Learned a few tricks over the years and it is not an issue anymore even for my old crippled fingers.
Looks like it should have been an OE part on my 05.
https://www.harley-davidson.com/us/e...ap/p/63134-10B
Life asked death “why do people love me but hate you”,
Death responded, “because you are a beautiful lie and I am a painful truth.”
‘Buddha’
Old 25th July 2021
Sorry guys...…. Maybe I need to change suppliers.
