0 NOS cases
Last Post: Yellowstone Kelly
Last Post: d10221
0 Ironhead engine problem?
0 72 ih stroker advise needed
Last Post: toe
Last Post: toe
0 WTB S&S super B parts
Last Post: bretton
Last Post: gl90hog
0 North central Mass
3 Wtb, Wts, Wtt, Wtg (Buells)
3 Wtb, Wts, Wtt, Wtg (XRs)
3 Wtb, Wts, Wtt, Wtg (EFIs)
3 Wtb, Wts, Wtt, Wtg (Evos)
0 BEWARE Of SCAMMERS!
0 Showa 54000088 Shocks
Last Post: d10221
Last Post: JimVonBaden
Old 30th July 2021
SHAKY DAVE's Avatar
SHAKY DAVE SHAKY DAVE is offline
Sportster/Buell Model: XLX
Sportster/Buell Year: 83
Sportster/Buell Model #2: '85 ironhead drag racer
Sportster/Buell Year #2: xlh
SHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to all
Originally Posted by ChinCactus View Post
Stock isn't ALWAYS the answer. My buddy has a 2003 Night Train. Near As I can tell, it is all stock. Thing has BAD low speed flop.
what do you expect from a stinkin evo????????
Old 30th July 2021
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
A 2003 Night Train was never built to go around corners. Fine in a straight line (just not at speed).
It was built to satisfy people who buy on the "Chopper" look. Big and heavy in the back end, long and light up front.
It's exactly the direct opposite for what is required to go around a corner fast.
Have a look at something like a 2003 Ducati to see what is done for fast, good handling bikes. Built for speed, not for looks.
At a walking pace a kids pump up scooter handles OK (or we wouldn't let our kids have them) But at 60 MPH ? I don't want to be on that thing.
Old 2nd August 2021
jsandidge's Avatar
jsandidge jsandidge is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: Suzuki GS850GL
Other Motorcycle Year: 1982
jsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to all
I sure am glad I took the advice of you wise folks. I put the longer stock (+2) tubes on and just got back from a ride. I love the ride now. I was able to return the shorter ones, so I'm only out the return shipping on them. Thanks guys!
Old 2nd August 2021
Blind Owl
Despite it's less than ideal geometry, poor suspension and excessive weight the Sportster does handle better than any Jap bike made before 1972.
It's low center of gravity and the weight help a lot with this.
If you were to lengthen and strengthen the rear swing arm, add longer adjustable dual rate shocks and replace he front forks with modern cartridge type with adjustable rebound and compression the bike will handle better than any 80's Jap bike.
But then, it wouldn't look like a Harley.
It would no longer be a chick magnet and the guys on those little 600 pocket rockets will still eat your lunch.
So, enjoy !
Old 3rd August 2021
kitabel kitabel is offline
Sportster/Buell Year: 1989
low center of gravity?
Iron cylinders and heads above the cases, large diameter iron flywheels - no jap bike has that.
Old 3rd August 2021
Blind Owl
You'd be surprised.
Centerline of the crank on a Sportster is just below the centerline of the bike. All of the 70's Jap 4 cylinders carry the weight much higher than you would think.
The seat height adds to this with most of the 4 cylinder bikes using "plank" type seats.
The width of these 4 cylinder bikes limits how low you can put the engine in a frame.
OK with frag bikes but try and get around a crooner on a CBX 6 cylinder Honda !
It's
here's another interesting fact.
When I went to build my first Sporton it finally dawned on me that the centerline of the engine was not on the centerline of the frame !
ie the engine is heavier on one side of the bike than the other.
Annd the engine is "offset" in the frame from where you would assume the centerline to be.
The good news was that it all made installing the engine in a Norton frame a piece of cake.
