0 Long intake
Last Post: dodgetrucken
0 CV40 carb vac slide
0 Axtell 88" info and Q's
Last Post: MrChris
0 TC88A update ?
0 Range With EFI 3.3 Gal Tank
Last Post: motorend
Last Post: MrChris
0 Why my daily speeds are generally slow
0 Oil lines..
Last Post: Scott
Last Post: slamtry
Last Post: Bow only
0 Glyptal?
0 heat cycles
Last Post: seajay
3 New Speedometer
0 Seat- New purchase or recover?
Last Post: duffy
0 H0023.F Caliper pin
0 Head work
Last Post: jsandidge
Last Post: Tucsonmax1
0 Best Bang for your Buck Exhaust option?
Last Post: twinspeed
0 "S" model specific Q&A
Last Post: neilp
0 Buell History
View Poll Results: Can/could you see behind you with stock mirrors?
Yes, the stock mirrors are fine. 510 37.31%
No, I can't/couldn't see a thing behind me! 857 62.69%
Voters: 1367. You may not vote on this poll
  #561
Old 17th October 2019
Folkie Folkie is offline
My mate with a solid mount says he can see things very clearly in his mirrors.
And then he starts his engine …
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
These are working out better than expected. Not blurry, wide view of adjacent lanes, and they stay put. I have a good view behind me rising solo, but a passenger does obstruct the view a bit.
Sleepy LaBeef (July 20, 1935 – December 26, 2019) RIP
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Sportster/Buell Year: 1983
Other Motorcycle Year: 1969
And I bet it's not an Ironhead, either …
Old 17th December 2019
blurry at higher speeds due to vibration.
Are you sure that's not your eye balls vibing???
Another factor for some to consider (on the solid mounts) are the handlebar riser bushings...
Hellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud of
Last September my left mirror departed on a ride (stem snapped) and I bought a used set of longer ones. They look a little goofy but I can see behind me now.
Goofy is in the eye of the beholder. Seriously, who can even see the mirrors on your bike when you ride by them? I changed mine to longer stems a long time ago and nobody even notices them. I can see past my arms and shoulders now!
