0 su carb question
0 high milage sportsters
0 cam lobes
0 flat earther bites dust trying to prove the earth is flat
0 LIQUIMOLY oil additive whose using it?
Last Post: hexnut
0 Mid West Meet & Greet
Last Post: sprink
Last Post: oldboy
0 Figure Machine external breather
Last Post: TUCCI
0 Is static timing enough?
Last Post: Whitewalls
0 Changing engine oil
Last Post: TUCCI
0 fork reflectors
0 Changed gas cap and experienced problems
Last Post: dayypete
0 The huge difference 4 degrees of Advance makes ...NOT
0 Throw out Bearing
Last Post: robbie202
0 Who has gone from Jackhammer 570s to Impact 560s?
0 Touring on a Hugger
0 Battery cable length
Last Post: xl883lo
0 '86 1100 basket build
Last Post: Onlybckroads
0 Leineweber camshaft
0 Plug for Siren
Last Post: brixtonanima
0 TC88a DIY Power adapter ?
41caninek1 (79), InkyDoggy (69), shepsvettes (67), outlw (48), outlaw05 (48), bklyngeezer (47), Skinn (46), theguy35 (41), IronHound (41), 2013iron883 (39), huge_midgit (33)
  #31
Jörgen Jörgen is offline
Bike Builder
Sportster/Buell Model: S&S XL124" streettracker
Jörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond repute
Originally Posted by madnss View Post
I’d love to know or hear about any quad cam that’s running 90 plus cubic inches, up to 103” Just to see how it compares. My assumption is that there aren’t many if any. Which is why the rules seem kind of ridiculous when they incorporate non existent combos that people do not run. Maybe I’m wrong, I’d sure like for someone to prove me wrong. Imho it’s equivalent to making rules for over bored 883s not to exceed 1200cc. Nobody is doing it so why in the hell Is it even a thing?
Old post I know.
It sounds like the rulemakers maybe are a bit dated regarding oem-cased builds? 103" was an S&S-combo on the 86- up motors if I remember correct. It was the 89" stroker kit combined with long 3-13/16 cylinders if I remember correct. Odd combo today
Does seem like they're living in the past. Not a good way to move forward...
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Old post I know.
Agreed
mac93 mac93 is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 95
I’m surprised some kind of comp eliminator format hasn’t evolved out of this.
madnss's Avatar
Agreed, blows my mind how most are afraid of change
madnss's Avatar
Super street was when it first started. Mixed in with hot street. Went one year and then the tears came. They actually separated it and ditched during the second season. Two low turn out classes would rather run separate, I don’t get it, but I enjoy a field that’s full as possible. 3-4 bikes in a class at a race meh
jcro61 jcro61 is offline
jcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud of
If you setup a class and nobody shows for it, that says something. To not change anything about the class and just expect it to magically grow is insanity. It is what it is.
this isn't just a trend homie, it's a lifestyle...
Just changing the lbs/cuin factor (multiplier) could make a huge difference. As is the only potentially competitive riders are those that weigh 165 lbs max geared up? What does that eliminate? 2/3 of those who might like to enter? That's a fatal flaw that won't self heal.
Prob 180-200lbs rider is the tipping point
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
What does your parts supplier suggest?
A lot of knowledge there.
