0 so it's officially ended
Last Post: XL1275
0 Xl???
Last Post: FrankGS
0 old parts
0 '66 XLCH VM38 Conversion
0 CV Carb hesitation
Last Post: owlsplace
Last Post: Nicktater
0 Tuners
0 Morning default to odometer
0 What jets do you use?
Last Post: Thack
Last Post: Samedward
Last Post: tedcool
8 XLCH kicker giving me a major headache!
Last Post: Nightmare
Last Post: 1200CustomHD
Last Post: OCRyder
View Poll Results: Average riding, not 200 mls at 40 mph, what do you get?
20-40 mpg 279 17.48%
40-50 mpg 964 60.40%
50-60 mpg 325 20.36%
60+ mpg 28 1.75%
Voters: 1596. You may not vote on this poll
  #611
XL Dane XL Dane is offline
Sportster/Buell Model: Sportster 48, 1275 + 570
XL Dane is an unknown quantity at this point
I corrected the speedo a while ago, but I thought that the ECM knew the precise fuel consumption by using injector size and time?
But it needs to be calibrated, mine was way off as delivered. I corrected the speedo VSS first and then dealt with trip center. In "Trip Center" you enter correction factors. It was showing I'd used ~ 2.5 gal when I was putting in 3.0. I ended up with a 1.18 "fuel used" correction factor so what it shows for "fuel used" matches what I put in. I'd reset the trip meter then run 3 or 4 tanks of gas recording how much I put in, 10+ gal with my 4.5 gal tank, and would then apply a correction and check again and correct again. It took a while. Now it's dead on, it was worth doing.
It's handy runnin' down the road, being able to watch "trip econ (mpg)" and have a good idea how far I can stretch fuel stops.
Thumbs up
Ok thanks, good to know.
Old 3 Hours Ago
Nicktater's Avatar
Nicktater Nicktater is offline
Sportster/Buell Model #2: XL883R
Sportster/Buell Year #2: 2002
Nicktater has a brilliant futureNicktater has a brilliant futureNicktater has a brilliant futureNicktater has a brilliant futureNicktater has a brilliant futureNicktater has a brilliant futureNicktater has a brilliant futureNicktater has a brilliant futureNicktater has a brilliant futureNicktater has a brilliant futureNicktater has a brilliant future
I’m between 48-52mpg. City streets to work, country roads on the weekend. Not sure which answer to choose. Way better than 40 and way lower than 60.
Do I have a death wish? No. But my bike is my reaper.
