0 timing sympstoms
0 Spokes and dual disc
Last Post: PetesPonies
0 Dale's Killer 40mm CV Carb
0 Do people notice your bike?
Last Post: RandyMac
0 1970 XLCH voltage
Last Post: Carboncore
0 Gravydog crashed again.
0 No working taillight, but bike still runs? Schematic included.
0 My cold weather attire.
0 How stock is your bike
Last Post: Lone Rider
0 Lowering, Geometry, and Physics
Last Post: koolbreeze
0 Getting bike all wet!
8 Crankshaft Failure
0 Ultima ignition
Last Post: Rigger10
0 Cheers from Germany
Last Post: Mr Snoid
5 popping in and out of first gear
Last Post: BlackBikeDave
0 Oil Pump Upgrade '86-'90
0 XR1200 Torquehammer exhaust failure.. again.
0 Who's still riding???
Last Post: Mr Snoid
0 XR heads on XL?
Last Post: Randy_rots
0 Aldbourne
0 Tires
Last Post: blackened
0 Sidestand lug
0 Forum member mug shots
0 Hyundai/Kia
0 A Day in the Life...
  #31
Old 11th July 2008
Fastfwd01 Fastfwd01 is offline
Sportster/Buell Model: XL1200N Nightster
Sportster/Buell Year: 08
Fastfwd01 is an unknown quantity at this point
Just got off the phone with the dealer….. August 15th before I might see a new caliper. On backorder apparently. Over a month on a part though? Wow!
I’m going to try this:
Originally Posted by Tristinator View Post
I had the same minor cross thread problem after removing the rear wheel on a 06 1200L. Every time I applied the brake the caliper would cock to the side giving me no pedal. Took it apart several times but everything looked ok. The caliper didn't look like it was cross-threaded. Had no pedal with the caliper bolt installed but a good pedal with the bolt out. Fixed the problem by loosely installing the caliper bolt so the treads barely touched, than having someone apply the brakes while I tightened the bolt.
If that doesn’t work then I’ll see about the helicoil.
Old 11th July 2008
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
I would look into the helicoil..........but also think about going aftermarket for the caliper so you don't have to wait on the lame ass MoCo to get one in when they feel like it............just a thought, places like J&P, Jeriah, Dennis Kirk all carry aftermarket calipers!!
RTFS
Ride That F'N Sportster!!
Old 13th July 2008
Well, I tried Tristinator’s suggestion and it worked like a charm. The caliper refused to build pressure while bolted up, but when I unbolted it I got pressure right away and then I tightened the bolt while it was being held pumped.
Man, I sure missed having my bike for a week and a half. I went up and cancelled that order for a new caliper.
Thanks everyone for your input.
Old 13th July 2008
tonefight's Avatar
tonefight tonefight is offline
Sportster/Buell Model: XL 883/1200
tonefight is a jewel in the roughtonefight is a jewel in the roughtonefight is a jewel in the roughtonefight is a jewel in the roughtonefight is a jewel in the roughtonefight is a jewel in the roughtonefight is a jewel in the roughtonefight is a jewel in the roughtonefight is a jewel in the roughtonefight is a jewel in the roughtonefight is a jewel in the rough
Guess I was wrong, I though for sure you were going to find it was the master cylinder. It just sounded too close to what I was dealing with to be anything else. Glad it all worked out without a major expense for ya, I wish I had been so lucky.
Old 29th June 2011
errorunknown's Avatar
errorunknown errorunknown is offline
errorunknown will become famous soon enougherrorunknown will become famous soon enougherrorunknown will become famous soon enougherrorunknown will become famous soon enougherrorunknown will become famous soon enougherrorunknown will become famous soon enough
+10000000
I had the same issue and looked everywhere for a solution. Nothing worked until I came upon this. I know it's an old old, but may save someone from buying a new caliper. Thank you sweet baby Jesus!
Old 30th June 2013
P@t's Avatar
P@t P@t is offline
Sportster/Buell Model: Forty Eight
P@t is an unknown quantity at this point
Add another +10000000!!!
it started with a flat tire then a broken bolt into the rear wheel and finaly when everything was set, I had no rear brake pressure.
Thanks to this post, it saved me from a rear brake job!
Old 30th June 2013
rocketmangb's Avatar
04-06 certainly has problems with the master cyl.
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 3rd March 2014
TheAnimal's Avatar
TheAnimal TheAnimal is offline
Sportster/Buell Model #2: Swift LSR
Other Motorcycle Model: FXDWG
TheAnimal is an unknown quantity at this point
Thanks for the thread, I just changed the rear tire yesterday and boom no rear brake. Picked up a new rear master cylinder from the dealer today and lost my mind when the pedal was exactly the same after installed. I came upon this thread after about a quart and a half of brake fluid and one very tired mighty-vac. I still can't get my head around how the caliper could or would bypass fluid due to the front pin, but I am happy it is such a simple fix. You guys rule!
Old 9th June 2018
major2 major2 is offline
Sportster/Buell Model: 883c
major2 is an unknown quantity at this point
I'm having this same problem. Changed pads and now no brakes. Is he referring to the bolt that goes through the eye of the pads? Which bolt do you loosen?
Napawineguy Napawineguy is offline
Napawineguy is an unknown quantity at this point
I know this is an old thread, but I had to put a new rear tire on my bike, and same thing happened, no brakes after, and ive heard this from quite a few other people had the same problem. I just rebuilt my master for the 3rd time, and I still dont have brakes. I bought a bleeder because of having a dry system after the first rebuild, and I did get them working once for about a week, and list them again. I just did the second rebuild since. I sure would like to know what the problem is. Even had a local shop look at the master after the last rebuild just to have them verify that I had done it right. It was not tested, but they told me everything looked right.
