Last Post: koolbreeze
Last Post: Sloppyburpfest
0 Early Sportster Shock Absorber Disassembly
Last Post: soundnav
0 Another Ohio Meet & Eat?
0 Nothing to See/Hear
Last Post: Tater66
0 Fuel Sputter & Much More
Last Post: SLW210
Last Post: maltesefalcon
0 Starter wouldn't shut off
Last Post: Doc308
0 Hagerty Insurance
0 New from Michigan
0 D&D Bobcat Fitment Question
0 T bars or Apehangers???
Last Post: D-RAIL
0 05 carb rebuild no start
Last Post: Legion Prime
0 73 XLH For Sale, what's it worth
0 Boring intro
0 Howdy From Texas
Last Post: FiftySixer
0 Help Identifying Pistons
Last Post: Staffords
0 Chinese S&S carbs
Jacquesnuenen (73), ocndaf (63), Wild Child (51), jetdoc1971 (49), Jmoses71 (49), Naugahyde (46), binksy (43), disasterousmark, KOOOPSD (35)
Old 22nd July 2019
USAFpj USAFpj is offline
Sportster/Buell Model: Ironhead Sportster
USAFpj is a glorious beacon of lightUSAFpj is a glorious beacon of lightUSAFpj is a glorious beacon of lightUSAFpj is a glorious beacon of lightUSAFpj is a glorious beacon of lightUSAFpj is a glorious beacon of lightUSAFpj is a glorious beacon of lightUSAFpj is a glorious beacon of lightUSAFpj is a glorious beacon of lightUSAFpj is a glorious beacon of lightUSAFpj is a glorious beacon of light
Default Tubeless valve stem
Guys- I'm about to purchase (2) new valve stems for the Morris Mags- I plan on cleaning, painting, and running tubeless.
Is there any performance difference between the cheapie rubber valve stems vs. the chrome VTwin metal stems? I'm not interested in shiney stuff, just solid working stems on an old cast rim...
Old 22nd July 2019
Sadsack's Avatar
Sadsack Sadsack is offline
Sportster/Buell Model: Xlh
Sportster/Buell Model #2: FX
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 2014
Sadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud of
No difference.
I've often run with the devil, but I've never made any deals....
Old 22nd July 2019
cheap at auto parts shops
even get 90* for easy access.
Old 22nd July 2019
I noticed on my '06, that it has the really short metal stem on the rear "mag". I just assumed that it was to clear the rear caliper/mount, as it spins.
Old 23rd July 2019
I suspect the rear is short because one side has the rotor & the other the sprocket - less clearance to get your hose/gauge onto that valve compared to front wheel... Maybe the dual disc front wheels also use a low clearance valve?
Old 23rd July 2019
Bluto Bluto is online now
Other Motorcycle Year: 1973
Harley uses either depending on the wheel and supplies one of each with wheel installation kits. I'd just use whatever old photos show back when Morris mags were common on Sportsters and many other bikes. The hole for the valve is bigger for the rubber type IIRC.
Do the wheels have a safety bead? Not all older cast wheels are suitable for running tubeless, some still need a tube. Often the wheel itself is marked as such.
Old 23rd July 2019
auto parts store kits come with hole adapters, diff lengths and turn outs. my 01 sport has the same f/r.
you can run a tubeless on a rim without a safety bead. the bead prevents the tire from riding center when air is lost, this makes for a wild ride. an inexperienced ride will be taken aback but been there done that many times.
