0 Brand new 2020 XL1200NS
5 Cruise-Mate (Europe)
0 Down on oil
Last Post: Billy1200
0 Vintage tires
0 I need to polarize the generator each time I start the bike
Last Post: randy3934
0 Remember these?
Last Post: bill smith
6 Happy Birthday Iree!!!
0 ‘79-81’ rear wheel offset or spacing ing issue?
0 CV carb running way rich!
Last Post: mikethebike61
0 1275 Map For Thundermax...Need Help
Last Post: XL1275
0 Sticky Ironhead trans
Last Post: Hap
0 Koso hd-01-04 2014+
0 Rear lights
Last Post: ironsquirrel
0 New to Harley - 2007 883R
0 Cancelling auto renew
1981, solenoid, starter
Old 12th September 2013
YoungIronG's Avatar
YoungIronG YoungIronG is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: Bicycle w/cards in spokes
YoungIronG is a name known to allYoungIronG is a name known to allYoungIronG is a name known to allYoungIronG is a name known to allYoungIronG is a name known to allYoungIronG is a name known to allYoungIronG is a name known to allYoungIronG is a name known to allYoungIronG is a name known to allYoungIronG is a name known to allYoungIronG is a name known to all
Default part number for 1981 XLH
yes. i have a parts manual on the way, but i want to go head and order my next parts shippment so it will travel the weekend.
anyway. the part i need is 1981 STARTER SOLENOID
nowhere sales one that clearly states 1981, they all end 1980.
is it 71469-65b? 69?
then is it single bracket or double bracket?
thanks!
should i go with accel? jpcycle shows only one from Standard Moto Prod - but still no oem part number associated with it.
what i plan to do is get the solenoid and drop it and the whole starter unit of with a gray beard to have it rebuild. dont 'feel' like doing this right job.
thanks yall
Been through so much schit, you won't believe that I'm young.
Starting 1981 the starter motor and the solenoid are one assembly, not two separate parts as in 1980 and previous years.
Old 13th September 2013
YoungIronG's Avatar
oh, okay...
so what your saying is only the parts in the solenoid can be replaced since the solenoid itsself cannot be removed?
i need to test each componet or take the whole thing to a shop??
thanks for the help Mick
I do not have any experience with the 81-on solenoid/starter assembly. Perhaps someone else will comment.
You should be able to uninstall it, dismantle, clean, inspect and test. There is a chapter on it in the 99484-85 factory service manual page 5-9 to 5-16 - looks like everything you need to know.
The Nippon starter solenoid can be rebuilt for ~ $12 in parts from you auto electric shop.
Unless you need a new plunger +$12~.
Take all needed parts in to rebuilder to match up as there are many different layouts.
Make sure solenoid windings are correctly secured (bent tabs) or you will have trouble.
YoungIronG's Avatar
thanks fellas
i really just thought the fsm skipped over the solenoid removing chapter
