0 Throttle side turn signal failure
Last Post: OntarioIron
0 Riding music
0 Sportster drag bike
0 Fair price for used parts
0 Now I did it. Feel my pain
0 Oil not returning to tank
0 Mikuni - hangin revs
0 100 vs 110 front tire
0 Photos: King Peanut or Regular Peanut tank?
Last Post: rezchug
0 Sportsters in movies and TV
Last Post: joes95bobber
0 Xl???
Last Post: seajay
0 My '96!
Last Post: 1200CustomHD
0 Xr750
Last Post: SLW210
0 S&S Super E Carb
0 so it's officially ended
Last Post: robbie202
0 New to me '08 1200R
Last Post: PhiRR
0 TC88A update ?
Last Post: HOG63
5 Dynatek DSPT-1 ?
Last Post: HOG63
Last Post: CCC
Last Post: slojoe631
texrex (68), jjluvstoride (55), luisbmns (50), njstoehr (44), tacho75xlh (41), 80ironhead80 (31), Xttrackerr (25)
mag, magneto, xlch
Old 7th May 2016
Nailbomb Nailbomb is offline
Sportster/Buell Model: XLCH Chopper
Sportster/Buell Year: 1959
Sportster/Buell Model #2: Buell P3 Blast
Other Motorcycle Model: 1200R Roadster
Other Motorcycle Year: 2008
Nailbomb is an unknown quantity at this point
Default '59 xlch Magneto issues...
So late in the fall last year I came upon the issue of my '59 XLCH not starting. Initially this in and of itself didn't raise concerns, as its been a bear to get started for some time, but eventually with the help of a friend holding the plugs grounded to the engine I realized that I was getting no spark. The ground off the mag was removed to eliminate the wiring as a potential fault, still no spark.
I ordered a complete Morris MRA-R kit figuring it covered me for a basic points and condenser update, and the ability to retard the timing sure couldn't hurt either.
With that installed I'm still having no luck and have ordered a coil from Morris as well. I figured if that didn't take care of it, I would just pull it and send it out for restoration.
Prior to my cracking it open for the MRA-R kit, the last known time the magneto was open would have been in the early 80's. To my knowledge all that was done then was points and a condenser as well. For all I know this is the original coil still in here and it just gave up the ghost, and the hard starting problems could have been a weak spark signaling its death cry. Of course early ironheads with fixed timing have never been known for being the easiest to start, thus my possible denial of the situation.
Basically Just want to make sure I'm not overlooking anything, and that I'm on the right path to getting this thing sorted out. Thank you in advance for any help or advice.
Old 7th May 2016
scottfisher's Avatar
scottfisher scottfisher is offline
Sportster/Buell Model: FLCH
Sportster/Buell Year: 61
Sportster/Buell Year #2: 60
scottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to behold
Remove the mag from the bike.
Clean everything and double check your previous work.
with it back together, put your fingers on the coil and give the gear a snap with your fingers. Even with finger snapping speed, you should get a nice jolt.
Unless you are in a completely dark space it is tough to see spark at the plugs. Furthermore, a dirty cap, plugs etc will also aggravate the process.
Then take care to ensure you install it correctly or it won't start.
There is some really good stuff in the stickys regarding maggy maintenance.
s
Scott
'61 'CH
'60 'CH
Old 7th May 2016
The stickys that SF mentioned - http://xlforum.net/forums/s...d.php?t=465866
Welcome to the forum!
Old 7th May 2016
During re-assembly of the engine the mag was tested in a similar method, and spark was rather easy to see(this was six years ago however) Wires and plugs are very new, and ignition troubleshooting should always start with basics like that.
It received a new cap with the MRA-R, so that is fresh also.
Thank you for the link to the stickies. Some very cool information there, the sifton cam specs in particular.
Old 7th May 2016
bobber58 bobber58 is offline
Senior Master Bike Builder
Sportster/Buell Model: XLH bobber
Sportster/Buell Year: 1964
Sportster/Buell Model #2: XLH
Other Motorcycle Model: 883 Iron
Other Motorcycle Year: 2010
bobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to all
I tried that MRA kit in mine, it made it worse instead of better. Sitting that long the points could be dirty. Chances are your original coil is just fine. What plugs and wires are on it? Are you sure it's set correctly?
Old 7th May 2016
Did you find the mag troubleshooting sticky section?
Old 7th May 2016
Yes I did, I'm not about to dive into it today however, I have two bikes still running and the weather is nice, so I'm jonsing to go on a jaunt. I'll be more than happy to update this thread as I go, and list what I've done.
Its rather disheartening to hear that people have tried the MRA kit and found it to not act as advertised however...
Thanks for the welcome to the forum.
Old 7th May 2016
Plugs are NGK B-6L and wires are Accel 8.8
Yes timing has been checked, so it is set correctly. Timing was checked with a timing light while bike was running. Even with the timing off it should produce spark.
If your asking if the MRA is installed correctly, I followed the instructions to the letter and had the points set at .019 at largest gap in the retarded position.
Old 7th May 2016
rigidpanman's Avatar
rigidpanman rigidpanman is offline
Other Motorcycle Model: panhead
Other Motorcycle Year: 1949
rigidpanman has a spectacular aura aboutrigidpanman has a spectacular aura aboutrigidpanman has a spectacular aura aboutrigidpanman has a spectacular aura aboutrigidpanman has a spectacular aura aboutrigidpanman has a spectacular aura aboutrigidpanman has a spectacular aura aboutrigidpanman has a spectacular aura aboutrigidpanman has a spectacular aura aboutrigidpanman has a spectacular aura about
Are those plugs resistor plugs and are those wires suppressor core?you should have non-resistor plugs and metal core wires
Sent from my LG-D850 using Tapatalk
Old 8th May 2016
Master Bike Builder
Sportster/Buell Year #2: 1971
I have been running the same mag in my ch for almost 30 years. If and when it sits for a bit, I go through the same kick, kick, kick, no start. I know they can be finicky. I go through the same drill as you have, eliminate wiring, check points, timing ect. I then remove mag and do the spin test against a good piece of steel. hold coil springs about 1/8 - 3/16 away and give mag a quick snap. If that produces a fat spark,put it back in and start the bike. If no spark, I put mag into lathe, bridge a paper clip in close proximity to coil springs. Use the cap screw holes to ground and support paper clip. Hold body of mag and turn on lathe (300rpm ish). Keep arms ect away from rotating lathe and sparking mag. Mag should spark brightly. This works for me every time. If no lathe, 1/2 drill should work.
Not sure what this does, perhaps help recharge magnets?? Old timer showed me that long ago. My $.02.
