0 Brand new 2020 XL1200NS
5 Cruise-Mate (Europe)
0 Down on oil
Last Post: Billy1200
0 Vintage tires
0 I need to polarize the generator each time I start the bike
Last Post: randy3934
0 Remember these?
Last Post: bill smith
6 Happy Birthday Iree!!!
0 ‘79-81’ rear wheel offset or spacing ing issue?
0 CV carb running way rich!
Last Post: mikethebike61
0 1275 Map For Thundermax...Need Help
Last Post: XL1275
0 Sticky Ironhead trans
Last Post: Hap
0 Koso hd-01-04 2014+
0 Rear lights
Last Post: ironsquirrel
0 New to Harley - 2007 883R
0 Cancelling auto renew
ironhead, rocker box, xlch
Old 2nd December 2017
Bannach's Avatar
Bannach Bannach is offline
Sportster/Buell Year: 1976
Sportster/Buell Model #2: XLH1200C
Sportster/Buell Year #2: 1997
Bannach is an unknown quantity at this point
Default 76 Ironhead Rocker Boxes
Hey Everyone,
So I am rebuilding a 76 ironhead xlch. This is my first build and i am just learning by reading the manual and YouTube, so i am a bit of a newbie. I just put together one of my rocker boxes because i have to put in new rocker arms. Upon putting the rocker arms back in, one of them moves up and down like it should, but the other one has some resistance on it when i check the move-ability. I did put a layer of oil on the rocker arm shafts before hand. Is this normal? Does it just need to get broken in or more oil? Any help would be much appreciated!
Old 3rd December 2017
Monte03's Avatar
Monte03 Monte03 is offline
Sportster/Buell Year: 1969
Other Motorcycle Year: 82
I would check Arm Shaft to Rocker for smooth movement before Installing into the box, yes use engine oil to wet the parts, OEM uses Springs to take up the Thrust slack between Arm and Hardened Thrust Washer ( unlike a shovel that uses nice spacers ) . So the Spring does give Some Resistance and may add to your binding
Cycle World Oct 1962:
