Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Air Intake, Carburetor/Fuel Injection, Fuel, and Exhaust
0 Help to ID 1974 Sportster XLCH custom parts
Last Post: Beelzeboss
Last Post: Lone Rider
0 Sportster Street Tracker GSXR Fork Swap!
Last Post: Greg_Wayne
0 Tranny Question
Last Post: sltm1
0 Who's still riding???
0 Is this 1200R worth $4500?
0 WTB: Factory Ironhead 2-1 Head Pipes
Last Post: wrkdWS6
0 Motorcycle Events
Last Post: rhartlin
0 magnetos 101 questions
0 New member from Santa Clarita, CA
0 Bratstyle Japanese Influence Bike Photos
Last Post: toadfish
0 Old Parts
0 Hello from Waipu, New Zealand
0 mainshaft oil leak
Last Post: T_worth
0 ***DK Custom-LIMITED TIME Sweetheart Deals-Save 10% On Select Products***
0 In PA Or Nearby
Last Post: Wilkinson949
  #41
Old 11th January 2016
fishman's Avatar
fishman fishman is offline
Sportster/Buell Model: M2
fishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the rough
Originally Posted by Phelan View Post
Too bad about putting a carb on it. Certainly doable, but I think it would be way cooler to put 07-up XL Delphi EFI on it and a Dynojet Power Vision, since you already have a crank sensor. That way you could also utilize the auto tune features.
Also, you may want to add a bit more clearance between the rear rocker box and shock mount. The motor moves a bit in vibration because of the isolator design, and if you ever have a rear isolator fail in particular, you will have some serious contact there. Also, the tab on the frame behind the shock needs to go as well, or it will hit and bind the shock. The shock moves back and forth a few inches during travel, because of the pitch and design. You will need to account for this during your fabrication process as well.
EFI sucks ;-)
I made more clearance at the shochmount. I also had to grind i bit of the heads cooling ribs to clear the frame. The XB heads have a bit different disign than de TS heads.
Hesitation is not an option!
Phelan's Avatar
Phelan Phelan is offline
Sportster/Buell Model: EBR 1190 SX
Phelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud of
I felt that way too, until I learned to tune and utilize the advantages of EFI . Besides the better atomization and finite tuning abilities of EFI, you also have the advantage of adding fuel to the mix much later and closer to the combustion chambers, keeping its weight out of the air longer and allowing the air to build higher velocity.
Love is the never-ending act of forgiveness - Peter Ustinov
Phelan's Avatar
Originally Posted by fishman View Post
The wheel is being bored this week. I found a 65t pulley and i ordered the bearings and bushings. All for under 150 USD
Wow, grats. I stand corrected .
fishman's Avatar
My M2 did 100.1hp en 120Nm on the wheel with a carb. Thing ran like hell.
fishman's Avatar
Still have to fit it all, but should work...
Phelan's Avatar
Oh, carb works perfectly well. But a good fuel injection system will perform as good, usually better. That is a stout M2. My Uly only made 76 RWHP on the NRHS dyno stock, and 2 other Ulys performed similarly on the same dyno with just exhaust and ECM (75 and 80 RWHP). The last build I did on the Uly though made 104 on the same dyno. I have yet to break in and tune the current build to see what it will do.
Old 16th February 2016
fishman's Avatar
Today i was ready to fire up the bike, but no spark from the TC88a. Is there anyway of testing the TC88a? I've checked the wiring multiple times and everything is wired correctly.
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Do you have the MAP sensor in place?
Click Here to Contact Me
fishman's Avatar
Yes i have. Just tested the CPS did 4Volts AC.
Won't it work with a defective MAP sensor?
Old 29th February 2016
fishman's Avatar
Still no spark. Had a crane firebaal coil 2x3 Ohm. Replaced it with a 0.5 Ohm coil. Still no spark :-(
