3 Shaky Dave Recovery
0 spark plug wire ohms
Last Post: Kbetts
0 Finally Got the Kinks Out
Last Post: Proteus
0 2.18 Gearing Ratio For 5 Spd 1200??
Last Post: vagrant318
0 Getting ready to try firing it up after a year long rebuid
0 Head bolts and conversion
0 Alarm Time Out?
Last Post: brixtonanima
0 Finding an accessory power source
0 1972 XLH question
Last Post: 1Scooter
Last Post: marksfatboy
0 Rocker cover torx
0 FS: Forward Controls (2004 - 2013 Sportster)
Last Post: wrkdWS6
0 my recent ebay purchase
0 Who Runs Turn Signals?
Last Post: Tincan
0 '86 1100 basket build
0 Stretched Swingarm
Last Post: Racepres
0 cleaning method for cases
0 Is static timing enough?
Last Post: ccmman
0 Changing engine oil
0 su carb question
0 Touring on a Hugger
Old 8th April 2019
THEWILDONE THEWILDONE is offline
Sportster/Buell Model: 1200 XLC
THEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud of
Default Think my stator needs replaced
Battery is fully charged and load tested good at the parts store.
Going down the FSM here's what I have determined:
1. No voltage increase at battery terminals when running, somethings not charging.
2. AC output probed at stator connector is about 57V at about 2000 RPM
3. About .3 Ohms between each stator connector pins when probed.
4. I'm getting about .1 to .3 Ohms between BOTH stator pins and chassis ground. (One lead of the meter is on one stator connector pin and the other grounded)
The FSM tells me that the stator is shorted to ground as a result of #4 above. Can anyone confirm this??? Wonder how this happened?
Old 8th April 2019
Yep - Measuring from either stator pin to ground should be INFINITY - OPEN - NO CONNECTION
You might just have a short in the cable going into the stator - but most often, readings like this indicate a short in one or more of the coils of the stator - and not feasible to fix...
Is this the stock original stator?
Check The Sportsterpedia - The Best Kept Secret on the XLForum!
Old 8th April 2019
Thanks for the fast reply and confirming that!
The stator is stock and original AFAIK. 2003 ~30,000 miles. Any recommendations on a replacement unit?
Old 8th April 2019
rocketmangb's Avatar
Cycle Electric !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 8th April 2019
Cycle Electric !
Ordered it! Thanks!
Old 13th April 2019
Here's some pics of the stator job. I ended up wrapping some bailing wire around the new stator lead to pull it through the opening in the engine by the cam chest and down to the frame. Had to fiddle with it for about 15 minutes maybe and change my approach but it wasn't too terrible.
Wires are exposed here in this one, insulation is slipping off.
The winding at roughly the 9 o'clock position looks pretty crusty. I don't think the whole thing should be black either?
New stator next to OE one.
New one looks like a great piece. THANKYOU rocketman for the reccomendation. Looks solid!
You guys got any other reccomendations or things to look out for while I'm in here??
DAMN I'm tempted to order up one of those LedSled kicker kits while I'm in here. I've been DROOLING over that since I first discovered it. Also, all the people that bitch about hard starting with a kicker, and, the vids all over the net of people just kicking, and kicking and kicking are hilarious..... I know the flathead UL I have that some of you may know about always starts easy. There IS a ritual to it...
With that particular flatty it was:
2 or 3 twists of the throttle then kick it through with the ignition OFF. Repeat 2 or 3 times..
THEN.....
Turn the ignition on and prime one more time with a few throttle twists and if it was cold enough, turn the choke on and 90% of the time it would fire right up.....
Old 16th April 2019
koolbreeze koolbreeze is offline
Sportster/Buell Model: XLH1200S
Other Motorcycle Model: Harley Trike FLHTCUTG
koolbreeze is a splendid one to beholdkoolbreeze is a splendid one to beholdkoolbreeze is a splendid one to beholdkoolbreeze is a splendid one to beholdkoolbreeze is a splendid one to beholdkoolbreeze is a splendid one to beholdkoolbreeze is a splendid one to beholdkoolbreeze is a splendid one to beholdkoolbreeze is a splendid one to beholdkoolbreeze is a splendid one to beholdkoolbreeze is a splendid one to behold
You guys got any other recommendations or things to look out for while I'm in here??
Just a suggestion, when working on new electrical parts (or any parts for that matter) interior to the engine and new parts, they should be placed on a clean surface to keep contamination off the new parts.
Glad you found the issue and got it corrected. Enjoy the ride!
Old 16th April 2019
You're right. Definitely helps to keep everything clean. I know there is a fair amount of trash on the floor as seen in the pics... I typically use a combination of rags, compressed air or whatever else to clean something first, and then install it.
Really, my (relatively) clean bench is covered with other parts/projects etc, so I just laid the stators down on the ground in order to get some pics with nothing else in the background. Well aside from whatever is floating around on the ground haha!
Old 13th April 2019
Sportster/Buell Year: 1988
Kudos to IXL2Relax!
WTHEWILDONE, what trans lube are you running? That original stator looks etched black; GL5 gear oils tend to be
more corrosive to copper. It might explain the failure. My stator is older and was still copper coloured under the oil.
Old 14th April 2019
Yes, thankyou IXL2Relax!!!
I have only run GL-1 in it...... The weekend warrior that I liberated the bike from may have run something in there that was not the correct choice.
