0 Rain pants
Last Post: Rhode Warrior
Last Post: Scott
0 Which Battery?
0 lengthen master cylinder
Last Post: kobra50
3 Shaky Dave Recovery
Last Post: ezmerf
0 Broken bolt holes/ mounts, can they be fixed?
0 so where the heck is insane shane?
0 Sportster Cobra seat
0 cam lobes
0 Sleeve cylinders?
Last Post: spamer80
0 Glyptal?
Last Post: Coz
0 Ironhead in the uk
0 More PhotoBucket Horrors...
0 Brake line to short
Steph (54), yubman (49), Windesch (47), Mark_Bench (43), motherduce (41), sgtfry (38)
belt, drive, drivebelt, pulley, sprocket
Old 28th August 2017
KH_Iron KH_Iron is offline
Sportster/Buell Model: 883 Iron
KH_Iron is an unknown quantity at this point
Default Rear sprocket (pulley) - 883 Iron
Help,
Anyone know or able to measure the inner diameter of the rear sprocket (pulley) for a 2009 Iron? By inner diameter i mean the center hole which the axel goes through, ref. pictures.
All help appreciated!
KH
http://photobucket.com/user/KH_Iron/...ihjhg.jpg.html
http://photobucket.com/user/KH_Iron/...ltygg.jpg.html
http://photobucket.com/user/KH_Iron/...79lb0.jpg.html
Old 29th August 2017
Folkie Folkie is offline
Or a 28T tranny sprocket on any 2004-10 883.
erin313 erin313 is offline
Sportster/Buell Model: XL883/1212
erin313 is a glorious beacon of lighterin313 is a glorious beacon of lighterin313 is a glorious beacon of lighterin313 is a glorious beacon of lighterin313 is a glorious beacon of lighterin313 is a glorious beacon of lighterin313 is a glorious beacon of lighterin313 is a glorious beacon of lighterin313 is a glorious beacon of lighterin313 is a glorious beacon of lighterin313 is a glorious beacon of light
It is 2 1/4" on a 2005, I believe they are the same as yours.
It's the same. The 28T tranny sprocket is stock on all 883s from 2004 to 2010.
I think the question was the rear sprocket with the axle hole.
Correct sportsterpaul!
I'm looking for the inner diameter of the REAR sprocket, ref. pictures linked below.
Should be 68T.
Cheers
KH
Thank you Erin313!
And just to be sure, you are referencing the rear sprocket correct?
Cheers
Correct- rear sprocket/pulley.
Sorry; I was confused by the reference to a particular year, and to an 883. The rear wheel sprocket is the same (68T) on 883s and 1200s for all years 2004 onwards.
