3 Shaky Dave Recovery
0 Swingarm bearings - boy I'm glad I looked at them
0 spark plug wire ohms
Last Post: Kbetts
0 Finally Got the Kinks Out
Last Post: Proteus
0 2.18 Gearing Ratio For 5 Spd 1200??
Last Post: vagrant318
0 Getting ready to try firing it up after a year long rebuid
0 Head bolts and conversion
0 Alarm Time Out?
Last Post: brixtonanima
0 Finding an accessory power source
0 1972 XLH question
Last Post: 1Scooter
Last Post: marksfatboy
0 Rocker cover torx
0 FS: Forward Controls (2004 - 2013 Sportster)
Last Post: wrkdWS6
0 my recent ebay purchase
0 Who Runs Turn Signals?
Last Post: Tincan
0 '86 1100 basket build
0 Rocker Lockers - Quiet Down Annoying Top End Ticking
0 Stretched Swingarm
Last Post: Racepres
0 cleaning method for cases
0 Is static timing enough?
Last Post: ccmman
0 Changing engine oil
0 su carb question
0 Touring on a Hugger
Old 3rd November 2019
Not a terrible install, don’t need the locking block, dig up a 4” brass door hinge, it wedges between the teeth on the rotor and the teeth on the clutch basket. For removal I use a 1/2” breaker bar with a five foot piece of pipe over it for leverage. On your install be very careful routing your stator harness across the back of the engine and down ahead of the drive pulley. It might help to attach some cord or wire to your old stator leads as you fish them back up, then attach your new leads to it and carefully pull the new leads back down. Next, a torque wrench with at least 250 lbs. ft., I rented on from my local AutoZone, use red loctite on the new stator. Hope this helps.
Old 4th November 2019
Semper-guzzi Semper-guzzi is offline
Sportster/Buell Year: 2016
Semper-guzzi is a glorious beacon of lightSemper-guzzi is a glorious beacon of lightSemper-guzzi is a glorious beacon of lightSemper-guzzi is a glorious beacon of lightSemper-guzzi is a glorious beacon of lightSemper-guzzi is a glorious beacon of lightSemper-guzzi is a glorious beacon of lightSemper-guzzi is a glorious beacon of lightSemper-guzzi is a glorious beacon of lightSemper-guzzi is a glorious beacon of lightSemper-guzzi is a glorious beacon of light
Yeah for sure. I didnt know autozone rented torque wrenches.
Sent from my SAMSUNG-SM-G891A using Tapatalk
THEWILDONE THEWILDONE is offline
THEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud of
Please hijack away! Replacing the stator is no big deal and you should totally tackle it yourself, you can do it man. You will need either the locking tool or, an impact to get the nuts off. I prefer the impact method, just borrow one from somewhere, most auto parts stores do tool loaner stuff. Get a good service manual too. I think mine is the clymer service manual and it's better than nothing but leaves a lot to be desired..... an actual HD manual would be best. One of the nuts is LEFT HAND THREAD cant remember which one off top my head.
You basically remove your primary cover and possibly controls, then you unbolt the 2 nuts and pull the primary drive off as a unit, exposing the stator.
Yes, service the clutch, it might still have the grenade plate or spring plate. I like the stiffer barnett diaphragm spring but it definitely makes it a man clutch from the stiffness...
Replacing the throwout bearing wouldn't be bad either but you can get to that one easily later on after everything's buttoned up if need be....... do NOT cheap out on the throwout bearing, I had tons of clutch engagement-disengagement issues that stemmed back to the cheap shitty TOBs I was using.
Anything else just ask.
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
One thing to note is one of the nuts has left handed threads and one is right handed.
There is a lot of great info here in the Sporsterpedia
John Wayne - "The Shootist"
Thanks guys. There's some local to me who's got more tools in his garage then in mine. Think we could share a few beers and knock it out. I ordered the parts last night including plates to replace the spring plate in the clutch. I get to make a clutch compression tool now too ha ha.
F.W.I.W. the Auto Zone by me “loans “ tools out, but you “rent” them. A hundred dollar deposit, use the tool, bring it back and get your deposit back.
Oh, I’ve done six stator replacements, the brass hinge works great as a gear locker, you can borrowed off of a door in your house, .4”.
rejeanprimeau's Avatar
Buy a Cycle Electric stator couple with their regulator and no more problem.
Old 5th November 2019
I looked around at a bunch of cycle electric distributors, none sold it. And I already picked up a new regulator... not even sure my old regulator is bad now that I think about it.
Old 12th November 2019
That's what I said, it's right there in your quote of me lol.
Hippysmack's Avatar
I'm doing the same thing on my 98.
I have pics up in the Sportsterpedia for the detailed teardown from start although the last thing I have to do is remove the engine sprocket and clutch basket.
They are here, although rigid mount, most should be the same.
91-03 Stator Replacement
Nut removal / installation:
