Last Post: 83XLX
0 Carburetor opinions
0 ***DK Custom Products Outlaw Permanent HiFlow Reusable Oil Filter***
0 Are 2003-prior cams and cover a bolt-on swap?
Last Post: farmall
0 1960 XLCH in the UK
0 hot start and starter "coughs"
Last Post: clnsflknr
0 Clutch cable deal
0 C&C Solo Seat comfort?
0 Fuel Injection cleaner
Last Post: farmall
12 air leak from intake
0 A Day in the Life...
0 570's or 536, 560's @10:1 Compression
0 When Were You Born?
Last Post: Joe_jeep
Last Post: Wilkinson949
0 crank case breather
0 40mm CV vs. S&S Super E for Draw thought Turbo!
Last Post: MonkeyMadness
0 Bike sold leaving forum
Last Post: 11alan111
0 *DK Custom - M8 Softail Passenger Pegs - Now You Have Options - Intro Savings*
0 Ride Report for the 2019 Void rally
Last Post: Coop802
0 My new LED headlight
1988, clutch, pressure tool
Old 16th December 2012
JohnieGordon's Avatar
JohnieGordon JohnieGordon is offline
Sportster/Buell Model: 883 XLH Deluxe
Sportster/Buell Year: 1988
Other Motorcycle Model: Hyosung GV250
Other Motorcycle Year: 2011
JohnieGordon is a name known to allJohnieGordon is a name known to allJohnieGordon is a name known to allJohnieGordon is a name known to allJohnieGordon is a name known to allJohnieGordon is a name known to allJohnieGordon is a name known to allJohnieGordon is a name known to allJohnieGordon is a name known to allJohnieGordon is a name known to allJohnieGordon is a name known to all
Default 1988 clutch problem
Hello guys!
I'm in a little trouble right now. I've had a stator problem on my 1988 Sportster and decided to perform the repair myself. So, I got the service manual and did the job.
The manual says that you need a pressure tool (partNo.34761-84) to disassemble the clutch in order to get to the rotor and the stator.
I didn't use one (because when I barely touched the snap ring with a scroll driver, the pressure plate just pup-out in my hands).
I did everything else by the book, and didn't used the pressure tool to assemble the clutch either (cause after putting the snap ring back with a scroll, it seemed to be very tight, I mean, really really tight).
After mounting everything again, I did the clutch adjustment and my clutch doesn't works (I wonder why... hahahahahhaha). It seen that It's engaged all the time, like If I was always pressing the clutch.
When I try to engage any gear, I can hear it engaging, but when I release the clutch, the motorcycle just stands still.
Do you guys think this problem is due the non use of the pressure tool?? Or is it due the clutch adjustment that I might have made wrongly?
Thanks for your help,
Pedro
HD Sportster 883 Bobber (XLH Deluxe), 1988 -> USA / Hyosung GV250, 2011 -> Brazil
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Bump......
Originally Posted by Bob F View Post
Bump......
I'm kinda new in this forum thing, I don't know what that means... sorry about that.
One more thing. I went down with a multimeter today to test the stator thing and it seems to not produce any voltage. I have just changed it, I've inspected the rotor and all magnets were OK, tight in place, no damage, no heat marks, only some small metal pieces that I've cleaned (probably came from the older stator).
The test I performed was the one referred in the manual and youtube: turn on the bike, put the multimeter in the stator's output and you should get a 12Vts reading.
The numbers were jumping on my reading, even using the "alligators" multimeter connection type.
Does it has something to do with the clutch problem? I mean, I don't think the clutch needs to be disengaged in order to the stator produce energy.
Thanks in advance,
Pedro
planesane's Avatar
planesane planesane is offline
Sportster/Buell Model: 1200c
Sportster/Buell Model #2: xl 1200
Sportster/Buell Year #2: 1989
Other Motorcycle Model: x1 lightning
planesane is a name known to allplanesane is a name known to allplanesane is a name known to allplanesane is a name known to allplanesane is a name known to allplanesane is a name known to allplanesane is a name known to allplanesane is a name known to allplanesane is a name known to allplanesane is a name known to allplanesane is a name known to all
hye man u are fine. i have the same bike and im a trained mechanic. went to school for it. u will save me alot of typing if u give me a call.
alex (805)428-7201 . call me and ill help u with whatever u need
planesane's Avatar
if ur clutch was fine before its still fine.
maybe the adjustment. when u did the adjustment did u collapse the cable adjuster all the way?
Old 20th December 2012
Hey Guys, It's me again.
I'm here first to say thanks to "Planesane", I can't express how much I appreciated the help you've gave me to day. I really mean it, besides saving at least 350 dollars, I've get to know a very nice guy and made a friend. We still gonna ride a lot together man!
Second, I managed the clutch / stator problem. I'm gonna post a how-to and some photos in another tread, to help people in the same situation. Hope It can be useful.
The problem I was having was due a misplaced spring plate that I put wrongly when assembling the clutch. Thanks to "Planesane" now I know how to fix it. He thought me how to do it and now my bike is working great.
Here is the link for the new tread:
http://xlforum.net/forums/s...58#post4261858
See you guys!
planesane's Avatar
I would have to say the only problem we ran into was me getting lost going to pick him and his bike up!! atleast he got to ride it home.
