0 Big bore Stroker problem
6 brake caliper spacing
Last Post: swampig
0 Fyi
0 Bike wobble question
0 One More Ohio Meet & Eat?
0 New oil tank
0 Perfect riding music
Last Post: seajay
0 Gear Spacing Question
0 1969 Shifter shaft bushing
Last Post: sleighcrane
0 WTS: Forward Controls 2004-13
0 It's Glamazon's Birthday!
Last Post: XL1275
0 too much oil in primary
0 Oil leaking
Last Post: tizard
0 Rear cylinder exhaust nuts
Last Post: XL1275
0 Thread pitch for 91 front engine mount bolts.
0 stumble
0 Done for now (no really)
Last Post: Eric Von Zipper
5 Favourite grips?
0 What Carb
Last Post: salmanmr
Last Post: jcro61
clutch, primary, slip
Old 17th November 2013
John_43 John_43 is offline
Sportster/Buell Model: Sportster 883XL
John_43 is an unknown quantity at this point
Default clutch is slipping..?
howdy. I have an 06 XL883 and I am stuck.
my bike "slips" in gear, and I can't figure out why. when the problem first arose, I was about to pull out of a parking spot and tried to accelerate. the primary made a really loud chattering noise and barely responded to throttle action, so I shut off the bike and opened the primary chain inspection cover. a bit of smoke was visible, and the clutch smelled like it burnt up.
I bought new clutch plates and a new compression spring and threw them in yesterday, but the bike still "slips"... It sort of behaves as if the clutch was pulled in while in gear. that's to say I can move the bike forward and back -in gear- without pulling on the clutch. it sort of stutters when it moves (in gear), as if something (?) was alllmost catching to keep it in gear, but then can't quite catch. the clutch cable is adjusted fine; I've done several readjustments to be sure.
I think this is an unrelated problem, but in addition to that the bike isn't kicking over. when I hit the starter, I hear mechanical action but it doesn't get the bike going. I'm pretty sure it's just fouled plug(s), but haven't looked into it much yet.
any help is appreciated.
XLXR's Avatar
XLXR XLXR is offline
Did you remove the spring plate and replace with extra plates?
Did you check the total height of all the clutch plates?
Did you verify the splines on the clutch basket were not worn with grooves from the clutch plate tabs which prevent the plates moving enough to engage?
Did you verify the ramp adjustment completely released the pressure of the clutch plates when the hand lever is let go?
The adjustment in the clutch cable is used to set hand lever free play after the ramp mechanism at the clutch is adjusted. Did you do that correctly?
checked all of the above, and double checked. Still the same problem. I think it's somewhere in the gears (sorry for the vague terminology, I'm unsure of what exactly to look for)? the stuttering doesn't seem to be from the clutch the more I look at it. it feels like the bike is catching a gear, but can't stay engaged. it definitely has the same problem in 1st and 2nd. any idea what else to look for?
Old 18th November 2013
pat5150's Avatar
pat5150 pat5150 is offline
Sportster/Buell Model: xl1250r
Other Motorcycle Model: xlh
Other Motorcycle Year: 1969
pat5150 has a brilliant futurepat5150 has a brilliant futurepat5150 has a brilliant futurepat5150 has a brilliant futurepat5150 has a brilliant futurepat5150 has a brilliant futurepat5150 has a brilliant futurepat5150 has a brilliant futurepat5150 has a brilliant futurepat5150 has a brilliant futurepat5150 has a brilliant future
There was a thread a bit back that showed the main drive pulley having been stripped...
The teeth on the inside of the pulley were toast. Ill try and find it for you.
The starting issue might be the battery. Stock battery?
Sent from my EVO using Tapatalk
yeah, stock battery. but lights work, not weak or anything. also the starter seems to be functioning fine, just no response in the motor... which is why I suspect plugs.
pat5150's Avatar
http://xlforum.net/forums/a...t-1677251.html
[QUOTE=pat5150;4642052]There was a thread a bit back that showed the main drive pulley having been stripped...
i sort of don't think it's that, since when I roll the bike the belt turns normally. but that IS with no load on it from the motor. So I'll check it to be sure.
XLXR's Avatar
Sounds like you have two unrelated problems. Sounds like you need to have a good mechanic look at it before the damage gets even more expensive.
