0 FIXED: Replcement of burned LED in indicator light board
0 Wanted (Buell Inlet Manifold)
Last Post: gusm2
0 What Carb
0 New oil tank
0 Hello from Holland
0 2007 LED Neutral etc display cluster/bar
Last Post: 45Brit
0 WTD: XL1200S SE Ignition module
0 Reassemble engine
0 Repainted my bike
0 add oil and ride
0 The SPORTSTER car?
0 primary register screw
0 Halloween 1250 Conversion
0 Strengthening 73 rear shock structure
Last Post: mikethebike61
0 One More Ohio Meet & Eat?
0 Adjustable Levers / Mueller Power CLutch
0 Thread pitch for 91 front engine mount bolts.
0 extra hole in neck web
0 91 883 sporty died while riding, will not crank.
0 Do you Run a Fuel Filter?
0 Who is the top hd engine builder in southh fkorida?
Last Post: FiftySixer
0 Expert brothers help! Moto iron springer install on bone stock 2001xl
0 New EU rules?
0 Points Assembly - Circuit Breaker Cam and Alignment Pins
black pearl (76), SDREDD (59), pig (57), BonRu (55), cbass (47), ssm7530 (45), HawkeyeTX, SxysCowboy (37)
clutch, gearing, primary, sportster, transmission
Old 29th May 2014
sportbob769 sportbob769 is offline
Sportster/Buell Model: XLH 1100 Sportster
Sportster/Buell Year: 1986
sportbob769 is an unknown quantity at this point
Default 86 sportster gear issue...help!!
I have an 86 Sportster that wont go into 4th gear (simply acts like neutral). I tried doing a clutch adjustment, adjusted the primary chain, and changed the primary fluid thinking one or all of those might help. However, while it now shifts perfectly thru 1-3, it still wont go into 4th. For a few weeks prior to now it would be hit or miss going into 4th. It would either simply go into 4th without a hitch, or act like I somehow went into like neutral, but upon a second attempt to hit 4th gear it would go. Now it wont at all. Any thoughts as to what this might be and how to fix it? thanks.
Old 29th May 2014
dave76's Avatar
dave76 dave76 is offline
Sportster/Buell Model: Sportster XLH 1200
Sportster/Buell Year: 1990
Sportster/Buell Model #2: Sportster XLH 1000
Sportster/Buell Year #2: 1976
dave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to behold
Hate to say it, but the trans has to come out, it's the only way see what's going on.
1990 1200 Sportster, Cycle Shack drag pipes, XLC forward controls, Zippers Billet 4 speed trap door.Update, 86 1100 heads, NRHS 1250 cylinders, Andrews V4 cams, and Compufire Elite 1 ignition. 07 Buell oil pump, Complete Andrews 4 Speed gears and shafts, Barnett Scorpion clutch. HHI 3' mid glide trees. HHI 6 piston front caliper, H-D floating rotor.
Old 29th May 2014
thats what I was afraid of...thanks for the reply.
Old 29th May 2014
Don Burton's Avatar
Bent shifting fork? Worn engagement dogs? Be glad that you don't own a rubbermount where the cases would have to be split.
Old 2nd June 2014
benton benton is offline
Sportster/Buell Model: Sportster Delux 883/1200
Sportster/Buell Year: 1988
benton has disabled reputation
Take it out. Change camshaft follower if you haven't already (use aftermarket steel version) Check out forks and all. Make sure it shifts on the bench.
