0 magneto twin plug heads
Last Post: marioserafica
0 Fun or money?
Last Post: bill smith
0 Does 20W60 reduce cam gear noise?
Last Post: XL Dane
5 Wet Dream, Ever Have One?
0 Down on oil
Last Post: Billy1200
0 1968 xlch
0 blonde, brunette, red?
0 Hamburger drum brake clunk noise
Last Post: nickfracture
11 How much did you spend on accessories in the first month?
0 Poll: Saddlebag Supports
0 I'm here to introduce Gristle.
Last Post: apotheon
Last Post: Randy_rots
Last Post: apotheon
0 Wish I had a beach with a ocean
Last Post: Akdawg
10 big bore question
0 Transmission figment
0 Smoke and top end job
0 2012 Superlow 883 settingfront Sag,need spacer Diameter info.
Last Post: Old Rocker
0 What’s the cost (Replace Clutch)
Last Post: SLW210
0 Carb not squirting fuel
Last Post: Kingrabbit
win307 (66), JrzyDave (59), WeirdNJ (59), Pigskinner (46), jeepsoldier (44), Virgdog (34), bernardderek, John Titor (22)
Old 6 Days Ago
npaisnel npaisnel is offline
Sportster/Buell Year #2: 1993
npaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond repute
Default Not a Sporty Carb..but CV
OK, So I have not measured it yet, but it apples to be the same sort of size and look identical from memory..
27088-95
Got a new CV carb here, trying to find out if it is basically the same as my 04 or 93 Sporty carb, with just minor jetting changes..will hang on to it if it is the same carb body with different jetting and needle etc.
Any one got a clue ..or is it a bigger carb...seems to be off a 95 Fatboy or similar from what i can tell.
Old 6 Days Ago
rocketmangb's Avatar
Likely still a CV40
Just jets and needle diff
There were some 44 and 51 SE carbs but would be marked as such
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 5 Days Ago
It's an HDI Dyna carb used from 1995-1998 with a factory 1.80 main jet, .42 slow jet.
Old 5 Days Ago
Thanks, for that, not yet popped it open to check jetting
Looks identical (from memory!) to the basic CV40, but wanted to ask,
Measured throat yesterday and yes, 40mm at butterfly end, so yes, very likely a standard CV40.
Thanks
