0 Swingarms
0 hi all
Last Post: Bow only
0 You can't tour on that!!!
0 the roadster make more power ?
0 question for our machinists
0 supply oil line seeping
0 Question on priming motor for kickstart
0 Interview of My Expieriences Riding in the Iron Butt Rally
0 Hydraulic Lift For XL
0 3.5" straight riser
0 Race tracks are harsh environments
0 Fact or fiction?
0 Cometic Air Cleaner Gasket?
0 Fork Upgrade to 39mm. Is This Possible/Wise
0 Very Loud Backfiring (among other things)
Last Post: Nacs
Last Post: olrider
5 Crankcase Oil Drain Plug
0 Winter riding clothes
Last Post: kobra50
5 Your worst car?
Old 12th April 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Originally Posted by hexnut View Post
If you do remove the heads you can re use the head gaskets. I have several times. Aaron says they re use them in the shop till the finish wears off. LOL
I think in this case, even the paper ones would be good to reuse. Especially given the added 2lbs. final torque.
