0 Ebay ****evil knievel bike****
0 old style fender skirted
0 Top end failure
0 Difference in Clutch Levers 45356-07 vs kit 44992-07
0 Coil polarity
Last Post: Medyo Bastos
0 clutch issue
Last Post: zack2267
0 XR mutt race bike progress
0 N65C or N65A
Last Post: lespaul6
0 Ground Up Beginner Build
0 Rubber mount gas tank part
Last Post: awright2009
0 Sportster Fork Upgrade
Last Post: PetesPonies
Last Post: smilinbrad
0 1998 883 spits and sputters at around 3000 rpm
Last Post: Tommr
Last Post: Billy1200
0 HD Museum Video - 1968 IH Dragster by Tom Reiser
Last Post: thefrenchowl
Last Post: Pagey
0 Valve keepers won't come out
Last Post: LLOYD883
0 Turtle tank on '79 frame
ironhead, sportster, starter, wiring
Old 29th March 2016
jmstinelli jmstinelli is offline
Sportster/Buell Model: Sportster xlx 1000
Sportster/Buell Year: 1984
jmstinelli is an unknown quantity at this point
Default Starter wiring
Hello everybody, I'm pretty new to the forum I've been reading the forum for a while now and posting for the first time. I have purchased an 84 sportster in a bucket or two and have finally got it all back together and nearly all wired up! Except I can not for the life of me figure out the how to wire up the starter. My understanding is that I need a second solenoid or a relay for the stater to get enough voltage to turn over. If anyone has any pictures or a wiring diagram specifically for the starter I would really appreciate it. Any suggestions on the solenoid or relay would also be appreciated. I would just like to let you know that I am in my third year of college and I'm not looking for the top of the line or all chromed model. I am looking for a middle of the road one that I will be able to rely on and not have to worry about it leaving me stranded. All help on the mater is greatly appreciated and I am looking forward to your answer!
Old 29th March 2016
russzx6's Avatar
russzx6 russzx6 is offline
Sportster/Buell Model: 1000cc Ironhead Sportster
Other Motorcycle Model: 96 KDX200 Dirt Bike
russzx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to all
My wiring diagram here should help you
http://xlforum.net/forums/s...d.php?t=411626
24 beers in a carton. ...24 hours in a day . .. coincidence??
Old 29th March 2016
Screwloose's Avatar
Screwloose Screwloose is offline
Sportster/Buell Year: 1979
Other Motorcycle Model: Kawasaki
Screwloose is a glorious beacon of lightScrewloose is a glorious beacon of lightScrewloose is a glorious beacon of lightScrewloose is a glorious beacon of lightScrewloose is a glorious beacon of lightScrewloose is a glorious beacon of lightScrewloose is a glorious beacon of lightScrewloose is a glorious beacon of lightScrewloose is a glorious beacon of lightScrewloose is a glorious beacon of lightScrewloose is a glorious beacon of light
Most bike shops will sell, or can order, a starter relay conversion kit. It's meant to replace older relays with the little black square relays. Comes with harness and relay for about 20 bucks. Just put one on mine this past weekend.
Old 29th March 2016
I've actually talked to you in the past on here, I used your diagram to wire the whole bike and for that I would like to say thank you so much!!! Now maybe I'm really just missing something here or just as likely the guy I bought this bike from did something screwy. The way I read your diagram the positive side of the coil is attached to the wire coming off of the run/kill switch,is that correct? I tested all wiring that appeared stock and left things where the were in they were hooked up. The wire attached to the positive side of the coil runs into a connection on either the starter or solenoid,I think it's the solenoid I'm unfortunately away from my bike and won't see it for awhile... Now when I attach that to the run wire and hook up the battery when I turn that button to the run position the Bendix gear kicks out emidietly! And nothing happens when I hit the start button which was connected to the States post. I've tried this with a secondary solenoid as would have been typical of the time with the same results... I haven't been slow to try it with a relay like in your diagram however. I only find one post on the starter other than the one with the jumper wire from the solenoid. I'm thinking I may need to pull the starter and bench test it or get it tested.
Old 29th March 2016
I appreciate the thought but I don't see how that will help me at this time. It's like when the parts store tries to sell me the H4headlight harness which would make it cleaner inside the headlight bucket but non of them say which wire is what and thats a3 post plug. I know what my wires are on the bike but have no way to now on the light so what would I conno where?? You know what I mean?
Old 29th March 2016
Power wire from the Battery Positive terminal is directly connected to the Power Terminal on Starter Solenoid... The other side of the Starter Solenoid Contacts goes to the Starter Motor itself...
Starter Relay activating coil is powered by Start Button on handlebar (which is fed by the Run/Stop Switch) - Otherside of Starter Relay coil is grounded to frame...
Starter Relay CONTACTS get power from the Accessory Circuit Breaker and, when the coil is powered, provides power to the Starter Solenoid (contact E below)...
The Starter Solenoid, when activated, kicks forward the Starter Pinion Gear into contact with the Clutch Ring Gear - While at the same time, the internal power contacts close the circuit between the Battery Supplied Power and the Starter Motor itself...
Starter Motor Functions & Solenoid Internals & Externals
Picture of Starter on the bike - Arrows to connections
__o~~o__
IXL2Relax
Old 29th March 2016
Screwloose's Avatar
You might wanna look into getting a service manual, they are absolutely invaluable!
Old 29th March 2016
Screwloose's Avatar
Old 29th March 2016
__o~~o__
IXL2Relax
Are both of the images you posted model specific for my bike?
Old 29th March 2016
I greatly appreciate the model specific diagram! I believe I am starting to figure this out, it would be much easier if I were still at home with the bike though! Would you happen to have the key for what the wire colors mean?
