0 stress killer
0 hi all
Last Post: ironmanx
0 supply oil line seeping
Last Post: hexnut
0 New Member and a question
0 3.5" straight riser
Last Post: denguy
Last Post: MadMike_1126
0 Starter bushing/bearing install in primary cover
Last Post: 84cj
0 question for our machinists
Sportster/Buell Year #2: 2005
Other Motorcycle Year: 2018
stikflote is a name known to allstikflote is a name known to allstikflote is a name known to allstikflote is a name known to allstikflote is a name known to allstikflote is a name known to allstikflote is a name known to allstikflote is a name known to allstikflote is a name known to allstikflote is a name known to allstikflote is a name known to all
Default Mag wheels
I folks,
can I get a Mag wheel to fit my XL 1200C in place of the spoked one ??
will the brake rotor need changing ,or can use the same one?
Keith
Glamazon Glamazon is offline
Sportster/Buell Year: 2014
Should be a straight swap especially if you stick to the same year. Spindles changed one year but can't remember when
sml1226 sml1226 is offline
08 changed to 25mm (from the 3/4" every 2000-2007 uses). The bearing cup got shallower for the thinner bearings.
An 08-12 (maybe... whatever year the Iron got the new 13 spoke with the tapered hub) Sporty with the 13 spoke cast narrow wheel should work fine though. I'm pretty sure they were just running a spacer to fill the extra 6mm in those as opposed to redesigning the hub for an existing mold. So anything pre-08 works basically.
And you can re-use your rotor if it's still good. No issues there. The hub is the same width on all of these wheels, and the rotor spacing hasn't changed since they went to sealed bearings.
harley506d's Avatar
Sportster/Buell Model: 1200c
Take a look here.......
http://sportsterpedia.com/doku.php/t...k:evo:wheels01
SLW210's Avatar
SLW210 SLW210 is offline
Sportster/Buell Year #2: 2019
2005-2007 use a 1" (25.4mm) axle AFAIK. Most any single disk brake sportster wheel should work, just need to match bearings, axles, spacers. That link has a lot of information and should be a few threads on here for other situations. I think some other Harley models wheels could fit IIRC.
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
... (from the 3/4" every 2000-2007 uses)...
Depends on whether you are referencing the front or rear wheel
Front:
2000-2007 - 3/4” Axle
Rear:
2000-2004 - 3/4“ Axle
2005-2007 - 1” Axle
From the Sportsterpedia, check under wheels, brakes & tires
John Wayne - "The Shootist"
Yeah, I was thinking front the whole time... Rear is different, true.
You can get 15mm thick 1” bearings though, so not as restrictive in wheel selection back there if you‘ve got a 1” axle and need them.
But no, newer 25mm wheels do not work on either end with original bearings. The hubs are spaced for 15mm thick bearings in the new wheels and the 3/4” and 1” bearings are 21mm thick. You get overhang. Not sure how safe that would be even if you made spacers fit the assembly.
Joe_jeep's Avatar
Joe_jeep Joe_jeep is offline
Joe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant future
is your current front wheel a 19" or a 21"?
im looking for a used 21" wheel.
