0 stress killer
0 hi all
Last Post: ironmanx
0 supply oil line seeping
Last Post: hexnut
0 New Member and a question
0 3.5" straight riser
Last Post: denguy
Last Post: MadMike_1126
0 Starter bushing/bearing install in primary cover
Last Post: 84cj
0 question for our machinists
Sportster/Buell Year #2: 2005
Other Motorcycle Year: 2018
stikflote is a name known to allstikflote is a name known to allstikflote is a name known to allstikflote is a name known to allstikflote is a name known to allstikflote is a name known to allstikflote is a name known to allstikflote is a name known to allstikflote is a name known to allstikflote is a name known to allstikflote is a name known to all
Default spot lamps
Hi ,all
i want to fit some spot lamps on my XL C ,any one have idea of which to buy,
will need the bar as well , has anyone used LED lamps
Keith
mickey t's Avatar
mickey t mickey t is offline
Sportster/Buell Year: 79
Originally Posted by stikflote View Post
Hi ,all
Keith
E bay
Sent from my SM-J260A using Tapatalk
Glamazon Glamazon is offline
Sportster/Buell Year: 2014
Harley have on the Heritage Classic.It'll cost you though! Ive seen spotlights & bars on Sportsters so there must be kits out there
Folkie Folkie is online now
I put Harley auxilliary lights on my '05 Custom. No need for a bar.
Not spotlights as such; why do you want spotlights?
I bought a used bar off Fleabay, cut the connectors and splice the wires into my headlight bucket on my Kawasaki.
Of course, I should have included an on / off switch to save the charging system when they weren't needed.............
The horns behind the bar I bought from a wrecked Chevy at the junk yard.
Folkie.
why the tax disc? on that lovely bike of yours
Because that pic was taken back in November 2009, when we still had to have tax discs. That bike is long gone. I had a few bikes in between, and now have this:
Nibelungen's Avatar
there are many products
many little, powerful, led spotlights you can fix right on the fork tubes...
useful if you ride at night often in the countryside...
with them, imo, better to have an empowered battery
if the end justifies the means... then who does justify the end?
