Keep & Kill
Last Post: Yakcm2
3 Weeks Ago
Posts: 701 Sportster/Buell Model: ironhead sporty Sportster/Buell Year: 79
Questions on popping after start
Ok so I changed the setting on the needle in the vm38...it says to start off w clip in the 3rd notch....I raised it one to run leaner for my plugs shows I'm running rich.(black soot) so kicked it couple times n forced up but on this one I got lots of popping out the pipes...any thoughts from ya guys in which i truly appreciate n am grateful for how far ya guys got me on this 71xlch
Sent from my SM-J260A using Tapatalk
3 Weeks Ago
Posts: 10,378 Sportster/Buell Model: XLCH Sportster/Buell Year: 1975
The jet needle doesn’t really come into play until about 3/4 throttle (twist grip position). Scroll to the end of this guide for a chart showing when each tuning item comes into play...
http://www.mikuni.com/pdf/vmmanual.pdf
3 Weeks Ago
Chief of Security
Posts: 2,323 Sportster/Buell Model: 1200/1250C Sportster/Buell Year: 05
So when does the main come in then? Cuz the needle comes in more like 1/4 throttle to 3/4 throttle on the hsr42.
3 Weeks Ago
My apologies, it looks like I misspoke. Looking at that chart again at the end of the guide the black diamond for the needle begins at 1/4 throttle opening and tapers off at 3/4 throttle. The main jet begins around 2/3 throttle opening to full open.
3 Weeks Ago
Posts: 1,299 Sportster/Buell Model: xlch Sportster/Buell Year: 1964 Sportster/Buell Model #2: XLCH IR EFI Sportster/Buell Year #2: 1971 Other Motorcycle Model: BMW K1200RS Other Motorcycle Year: 2001
Needle below the retaining plate?
3 Weeks Ago
If I'm following what your saying correctly, yes...needle first then the locking plate which I'm sure is the retaining plate.
3 Weeks Ago
Correct.
3 Weeks Ago
Re check your batt voltage.I f iremember correctly you had some batteryand/or charging issues previously? Also verify electrical connections at coil and plug wires. Do small changes one at a time.
3 Weeks Ago
Yeah got battery straightened out...reads 13...n kept on trickle charger...checked spark plug wire connections n all is good
3 Weeks Ago
Look for a manifold leak or leak around the manifold to carb fitment.
