Last Post: Counter Steer
0 Solenoid rebuild drained battery
0 Use Force Sportster Exhaust
0 2003 883R Progressive Fork Springs?
Last Post: mikam123
0 Exhaust Wrap
Last Post: TheSterling
0 Slip on muffler
Last Post: Hellbent_4
0 Photos: King Peanut or Regular Peanut tank?
Last Post: rezchug
0 A Day in the Life...
0 derby cover leak
0 2020 Sportster models on Federal EPA website
Last Post: Bored now
0 Massachusetts rides 2019
0 Helmets Please...
14 Hogtunes In-Fairing Bluetooth Audio Controller
0 what size battery is appropriate?
Last Post: The Doctor71
0 Help! VOES And hose
Last Post: unitedcycles
0 I need help sourcing a stroker crank
5 What can cause the engine to suddenly misfire?
Last Post: Whitewalls
0 Changing DNS Servers
Last Post: Tonyb65
smm1200 smm1200 is offline
Sportster/Buell Model: 1200xl
smm1200 is a glorious beacon of lightsmm1200 is a glorious beacon of lightsmm1200 is a glorious beacon of lightsmm1200 is a glorious beacon of lightsmm1200 is a glorious beacon of lightsmm1200 is a glorious beacon of lightsmm1200 is a glorious beacon of lightsmm1200 is a glorious beacon of lightsmm1200 is a glorious beacon of lightsmm1200 is a glorious beacon of lightsmm1200 is a glorious beacon of light
Default EFI fuel tank hose fail
Working on cleaning up the tank, pump system and injectors after sitting with lots of rust. Finally ready to start going back together and now find the tank hose has failed at the tight bend near the tag. The hose is very soft, and my spray needle would not go thru that section....obviously the inner liner has failed. Check yours by feel for soft and different than the remainder of the line....easy to do. Would have hoped that HD would have changed this and added a 45 at that manifold end so it would clear the frame before bending to the tank.....but.
Air-Cooled Forever
A pic would be nice. just sayin'...
Would normally agree, but you cannot see anything on this line unless you bend it into a tight knot....I could not see anything wrong, but the cleaner straw would not go thru the line.....got me goin.
Air-Cooled Forever
Do you think a tank lift would help or just cause a new set of issues?
Good question, but I think the problem is that there is little room between the frame tube and the line causing the bend. The hose then wraps around to the tank....so would prob not help things.
