Last Post: Turbo Sporty 48
0 Please please please
Last Post: HarleyAsh
Last Post: Sporty1989
0 Coil test
0 Saturday Sportster Season 2
Last Post: rocketnorton
0 XR1000 for sale! (Won't be cheap.)
Last Post: 84rzv500r
0 Allegheny 2023
Last Post: sprink
0 Chrome
Last Post: Andy Hog
0 Here is my new 61XLCH
0 FNG from Tuckasee
Last Post: Tyler45
0 It's been a great Ride!
0 The White Bike is the Right Bike Thread.
Last Post: Valantine
0 Torque is never enough
0 Right Passenger Foot Peg Assembly 2014 XL 1200C Sportster
Last Post: RKDoug
0 Left Passenger Foot Peg Assembly 2014 XL 1200C Sportster
Last Post: RKDoug
0 OEM H-D Horn Cover
Last Post: RKDoug
0 OEM Rear Turn Signal Supports off 2014 XL 1200C Sportster
Last Post: RKDoug
0 Harley-Davidson shocks off a 2014 XL 1200C
Last Post: RKDoug
ken_in_il (63), big andy (59), RogueFTW (57), higdon1200 (52), sastchimo (51), NUcadet12 (45), jswoperator (43)
Old 1st December 2022
joe_black joe_black is offline
Sportster/Buell Model: xls
Sportster/Buell Year: 1979
joe_black is an unknown quantity at this point
Default ironhead oil pump pressure
I have a 1979 XLS that I have ridden and wrenched on for 32 years and since I am getting older I am looking at putting a hydraulic clutch booster on the hydro clutch. My problem is if there is enough oil pressure at the pump to run the FeatherLever unit. I put a rocker box pressure gauge on several years ago and with a cold engine it would max out(30lbs) but when hot it idled at 8 to 10 pounds. I have never put a gauge on the pump output so I am wondering if anyone has any idea if the pump pressure when hot will be near the 30 pound level that I need?
I have all the fittings and parts but the bike is in the cellar for the winter and I can't run it to test and I have lost the gauge. If any of the skilled mechanics on this site think there will enough pressure I can install the unit and be ready to ride when the snow goes away.
The forum has been a valuable resource over the years and I thank you all for that..
Happy Solstice
ericfreeman's Avatar
ericfreeman ericfreeman is online now
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
ericfreeman has a brilliant futureericfreeman has a brilliant futureericfreeman has a brilliant futureericfreeman has a brilliant futureericfreeman has a brilliant futureericfreeman has a brilliant futureericfreeman has a brilliant futureericfreeman has a brilliant futureericfreeman has a brilliant futureericfreeman has a brilliant futureericfreeman has a brilliant future
The Sportster oil pump is all about volume and not pressure. I doubt you'll see much more than 10 psi, if that, when the engine is hot.
Eric
wolfryder wolfryder is offline
Sportster/Buell Model: 1978 ironhead sportster
Other Motorcycle Model: 81 fxe lowrider
wolfryder is a splendid one to beholdwolfryder is a splendid one to beholdwolfryder is a splendid one to beholdwolfryder is a splendid one to beholdwolfryder is a splendid one to beholdwolfryder is a splendid one to beholdwolfryder is a splendid one to beholdwolfryder is a splendid one to beholdwolfryder is a splendid one to beholdwolfryder is a splendid one to beholdwolfryder is a splendid one to behold
The oil pump is not goanna make but 8/10 lbs. when hot. So what you can do is get a hydraulic set up and try that https://www.ebay.com/itm/25394634532...3ABFBMmrSb_Jlh
rejeanprimeau's Avatar
Isn't those Feather Lever work with already equip Hydraulic clutch and just act as a booster???
Sportster have a mechanical clutch and you'll miss some parts to make it work.
I have a Custom Chrome Clutchlite XXLite and I can pull my clutch in with two finger.
Sportster/Buell Year #2: '03
oil pressure is listed in the factory service manual.15 psi hot at 60 mph.
post #1 mentions he has added the hydraulic clutch and wants to boost that with the feather lever.have you seen the price on those??
Old 2nd December 2022
If it's a booster pump, just about any feeding pressure will be OK.
can you make it work, well, hummmmm
sure you can but will it be pretty??????
it is all about surface area and available pressure. if the slave is large enough, even 1 psi would do the job.
there are hyd calculators out there that can help crunch the numbers, just need to know the spring pressure to over come.
Old 3rd December 2022
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
Wait. What ?
Do you already have a hydro clutch and want to add a booster to that ?
If that's the case you need the services of a good sports physio. Ask at your gym, they will have one.
Alternatively, Honda mad a 750 Automatic back in the 70's. Might need to check them out.
Thanks for the replies - The reasons for the booster on the hydroclutch are due to nerve damage from chemotherapy and arthritis with carpal tunnel syndrome from old age. The hydraulic clutch is a big improvement but in traffic I have to stop once and awhile to rest both hands. I don't think it is going to work but anything to keep riding so I will keep on.
The bike has about two hundred thousand miles on it so the ugly of the featherlever unit isn't going to hurt the function the only original parts are the frame, cases and wheels.
