Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > GENERAL AREA > The BUY - SELL - TRADE Zone
Last Post: toadfish
0 A thunderstorm -weather that is
Last Post: oupa
Last Post: Beelzeboss
Last Post: Spokane2303
Last Post: JKKO
0 Hello from Waipu, New Zealand
0 POLL: Vance and Hines
Last Post: Bama Lee XLC
0 stock modded exhaust vs short shot
Last Post: elbozo
Last Post: Darkseacret
0 Fork Spring Rate measurments, sag and more
Last Post: pdavis5160
5 my 3D printed turn signals.. what would you print?
0 Frame-mount Danmoto baffle removal?
Last Post: Curbside
Last Post: davixlrtt
0 compression problems
Last Post: BWP 5p
0 02 sensor query
0 Chrome or Dark Custom
Last Post: frogg_nutts
Last Post: xkreedx
painterdude923's Avatar
painterdude923 painterdude923 is offline
painterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to behold
Default Need transmission 2003
I need a new transmission for my 03 1250 hammer powered bike.
shanneba shanneba is offline
Baker 6 speed-
https://bakerdrivetrain.com/collecti...nt=23267551235
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Air-Cooled Forever
Originally Posted by shanneba View Post
That'd be a great solution.
What's wrong with the old one?
Can't rebuild?
I had soon many chunks and pieces in there when I pulled it out today. I also have 98000 miles on it. I ordered a low mileage used one today going to have the zippers billet trap door swapped from my trans to the newer trans. I am going to go with a close ratio 1st, just trying to figure out if I want to go close 2.61, medium close 2.368? I want to get this bike into the 10s in the 1/4 miles this year!!
Hopalong48's Avatar
Hopalong48 Hopalong48 is offline
Sportster/Buell Year: 1966
Hopalong48 is an unknown quantity at this point
fallen cycles
Sent from my SAMSUNG-SM-G891A using Tapatalk
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
I’m close ratio 1st and second. I think I’m 2.61 if memory serves me correctly. It’s what was recommended to me by almost every xl racer, hammer dan and R&D in Florida.
Hey madnss! I talked to mark at r&d today. Wish I could have talked to him a while ago! Great guy and I know he does awesome stuff! He did matts beautiful trans for his 90inch! I am sending him my stuff, already got the 2.61 going in, I have a zippers billet trap door and he'll do his magic. I am so excited to have transmission that's going to be awesome for the BFH 1275 setup that I am putting together next month. Had hammer put a xr1200 crank in a couple of years ago. I have been following you and your progress over the years. Bad ass bud!! I use to ride 45 minutes to the track, run 11.70s a few times then ride home when I was living in Michigan. Hoping for some high 10s this year. Gonna try with a stock wheel base sporty anyway
Sent from my SM-T350 using Tapatalk
madnss's Avatar
That’s awesome! Mark is good stuff! And so is the Hammer 1275 BFH!!!! Good luck on the 10! I hope you get it!!!!!!
Is the bike still a street bike you ride a lot? And what’s the gearing? Stock primary gears I assume? Rear belt or chain and teeth count?
Yes almost all street riding. 520 chain drive, 21 48, deuce rear wheel, stock swing arm and lowered stock forks, 19inch front mag wheel for now.... waiting for my 120 hp setup, everything I need then sell my complete 110hp setup with crush XB heads, 560 cams, 45 mikuni with manifold, 1250 30degree big fin cylinders,ect.... help recoup some of the money for the new setup ya know?
