0 Chinese S&S carbs
0 Info needed on mini sumps.
Last Post: thefrenchowl
Last Post: james beam
Last Post: Tipofthelake
Last Post: keithnh
0 Valve Lengths?
Last Post: motorhedmike
Last Post: JonesL
0 73 XLH Total Power Loss
Last Post: sleighcrane
0 Cleaning carbon build-up
Last Post: commando57
0 Gasket placement
Last Post: Billy1200
0 XR mutt race bike progress
0 What oils do you run in your ironhead
0 Lifters+w cams
0 HF bike lift
Last Post: jharback
vt883, Danno, Otis_hd (70), Fisherman (69), New Girl (63), soup (58), motormyk (51), leo, UncleSmitty (43), bryguy1977
Gold Member's Avatar
Sportster/Buell Year: 1972
Gold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud of
Originally Posted by kitabel View Post
Not a 900?
"Sportster/Buell Model: XLCH
Sportster/Buell Year: 1972 "
I do have a 1970 900 engine but it's on the shelf. What I'm building here is my 1972 1000.
Stop by my build thread:
http://xlforum.net/forums/showthread.php?t=2076933
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Originally Posted by Gold Member View Post
I got 4, NGK B6L's locally. Thanks guys.
Another question I have is, can I just get any old 12V condensers, or do I need a specific value or something?
Condensers are rated by their capacity which is MicroFards (MFD) in our case. The higher the capacity the better a job they do.
Fit the highest capacity you can find in the physical space you have.
They perform two functions. They stop sparks across the points gap when they open.
A condenser isn't absolutely necessary for the engine to run but your points will wear out much faster.
