Last Post: class of 82
0 ***DK Custom-Announcing The 5th Annual Internet Bike Contest***
0 Tires
Last Post: kmul
0 How stock is your bike
Last Post: Bama Lee XLC
0 Howdy from Baytown, TX
0 Gravydog crashed again.
0 Screw Loose's Repairs
Last Post: Screw Loose Dan
0 Lithium battery earthx
Last Post: Tucsonmax1
0 Building a dragbike 101
Last Post: Racepres
0 Mikuni/Solex Dual Throat Tuning Instructions
Last Post: DBALTHASER
0 Seat Poll - Bad Ass or Fat Ass
Last Post: khav
0 Who's still riding???
Last Post: paulc
Last Post: Four Speed
Last Post: moparnut72
0 ***DK Custom-Thank You Veterans-Savings Coupons***
0 Timing Issue Newbie Help Please?
0 Mixture screw has no effect. Need help!
0 White Letter Tires
Last Post: ed_in_az
Last Post: dodgetrucken
0 1960 XLCH in the UK
Last Post: lynnx
10 Suspension pointers
Last Post: SLW210
14 How To: View HD Part #'s 1991-2010 - All Models - With Part #'s and Exploded Views!!
Last Post: farmall
clunk, clutch, release, throttle
  #31
Sportster/Buell Year: 1988
Manda, I think Wedge is right about the noise coming from the primary chain. A thought occurred to me; do you know how old the primary chain is?
Chains don't always wear evenly. Try checking the tension as you rotate the primary; you may find a slack point.
I fitted a modified Hayden tensioner to introduce some cushioning which reduced the abruptness of the transmission on my chain driven 88.
wedge's Avatar
wedge wedge is offline
Originally Posted by HotRod917 View Post
(cos we all like linear clutch progression and vehicle movement don't we) but everytime it happens it's really annoying and I'm like "Oh man here we go..F U sporty".
Well, there's that of course, however; I like the crazy quirks. It's an old design, and we all have our reasons for liking that. For instance, it's like your wife of 40+ years developed a limp. Sure, it's annoying, especially if she drops your beer but are you going to be like... "Oh man, here we go.. F U wifey"
On the serious side though. In looking for the knock I have mentioned in here already somewhere, I swapped the chain, and the adjuster foot. My knock is nothing like yours. In your situation, this does seem to be directly related to the drive train. I know you won't stop looking for it, and I'm still looking for my noise too. I would be looking at both belt sprockets engine mounts and links, as well as the primary.
kopbilly1's Avatar
kopbilly1 kopbilly1 is offline
Location: Southern California coast 25 mi north of Malibu.
Sportster/Buell Model: xl 883c anniverssary
Other Motorcycle Model: Suzuki gsxr1000
kopbilly1 is an unknown quantity at this point
i also have had a similar problem on my 2003. if it wqere the chain, i think it would make more of a pop or clank. the noise i hear is a low, solid, heavy noise. has anyone considered the pawl adjustment?
wedge's Avatar
Originally Posted by Manda View Post
There's also situation when you slow down in 2nd and its time to downshift (RPMs are really low and and bike lugs/jerks), but instead of downshifting, you twist the throttle and it snaps/clunks.
This does bring one other thing to mind. When you grab throttle while the bike is lugging, it can cause some kickback that you will hear as a deep knock. Maybe your timing is slightly over advanced on the low end. This can happen with a bike that is tuned OK for normal situations, and you shouldn't lug it anyway, so the easiest cure is to quit lugging it. You could try backing the timing off a degree or two and see if that helps.
I felt that on mine once pulling into a parking lot while someone was trying hard to T-bone me, so I gave it too much throttle in too high a gear for my RPM and it knocked like the bottom end was going to fall out right there. I didn't chase the timing, because I recognized it as my fault, and the problem hasn't returned.
wedge's Avatar
Pawl adjustment? I do not know of an adjustment for shifter pawls on my rubbermount. Is this something for earlier models?
Old 6 Days Ago
HotRod917's Avatar
HotRod917 HotRod917 is offline
HotRod917 has disabled reputation
Hahaha..thats good one, not married yet sir but i get it..just not gettin enough time to get into the primary and sort it out..I'm sure i can get to the bottom of this if I'm keeping my sporty long enough (Not cos I want to part ways with it but have to, we'll see) ..also did you check for clutch basket play and other tolerances when replacing the primary chain. If its not too much trouble could u repost ur original Knock comment so we can try and figure it out ..Thank you for the laughs
Dõvąhkiin
Old 6 Days Ago
Kbetts's Avatar
Kbetts Kbetts is offline
Other Motorcycle Model: Suzuki DL650ADV
Kbetts has much to be proud ofKbetts has much to be proud ofKbetts has much to be proud ofKbetts has much to be proud ofKbetts has much to be proud ofKbetts has much to be proud ofKbetts has much to be proud ofKbetts has much to be proud ofKbetts has much to be proud ofKbetts has much to be proud ofKbetts has much to be proud of
Mine does it when I’m trying to maintain a very low forward speed by modulating the clutch.
I think it may have something to do with the speed of the moving primary being faster than the input shaft causing force in reverse of normal acceleration on the clutch pack
If that makes any sense
Old 6 Days Ago
Folkie Folkie is online now
Yes; that makes perfect sense. That's definitely what it is.
