Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE & BUELL MOTORCYCLE FORUM - GENERAL DISCUSSION > Riding Tips & Safety Advice
Riding Tips & Safety Advice Got a question about your riding technique or safety issues?
0 Done for now (no really)
Last Post: Pagey
0 2007 LED Neutral etc display cluster/bar
0 New oil tank
0 It's Glamazon's Birthday!
Last Post: ronccc
0 Fall 2020 GBB - kind of....
0 SE.536 cams, who has a set sitting around
0 Cruising RPMs
0 One More Ohio Meet & Eat?
0 XLCH chainguard
Last Post: ricusa
0 Rare As Hens Teeth? (Stock Parts Secondhand)
3 Wtb, Wts, Wtt, Wtg (EFIs)
Last Post: toomuchstuff
0 Big bore Stroker problem
0 Oil leaking
0 Repainted my bike
Last Post: chilly
0 newbie
0 Gear Spacing Question
View Poll Results: Do you blip the throttle when downshifting?
Always / Most of the time... 669 56.46%
Sometimes / Depends on the circumstance... 343 28.95%
Never / Hardly ever... 173 14.60%
Voters: 1185. You may not vote on this poll
  #471
Old 11th April 2020
Highly-Dangerous's Avatar
Are we still beating this dead horse?
You blip the throttle to MATCH REVS (RPMS) TO THE ROAD SPEED IN THE LOWER GEAR.
It makes for a smoother shift.
It has nothing to do with double clutching a non-synchro transmission. We have dog type sequential transmissions that will shift just fine (but not smoothly) without rev matching.
Ride with a passenger. If you don't rev match you'll be banging helmets every time you down shift. It will be a learning experience.
Exactly! thats why I taught my wife to blip the throttle on downshifting, she got the hung of it pretty quick and now she loves it.
Smooth is good!!! I've been blipping the throttle always on all my bikes... its second nature on me.
Old 11th April 2020
Google the Nissan 350Z manual transmission with the automatic rev-matching throttle which is controlled by the ECU. It does it better than a human driver and gives perfect manual shifts.
Blipping is not mandatory but it sure improves the shifting in a car, truck or motorcycle.
Why is this so confusing?
While you're at it, google how people used to shift gears - up and down - without synchronizers. The transmissions were called "crash boxes" for a reason. My first two cars had non-synchro first gear and it was a right of passage to smoothly downshift into first while moving.
Old 19th September 2020
iNSaNeSHaNe's Avatar
Sportster/Buell Year: 1985
Blip! Blip! Blip! Blip!
THE Bike Goes Blip! Blip! Blip!
Now We're going a Hundred and Ten
Blip! Blip! Blip Blip! Blip!
I Just Bang it and slide the back around
It'll match the revs at some point ...
Proteus Proteus is offline
Sportster/Buell Year: 2012
Other Motorcycle Model: BMW R 75/5
Other Motorcycle Year: 1972
Proteus has a reputation beyond reputeProteus has a reputation beyond reputeProteus has a reputation beyond reputeProteus has a reputation beyond reputeProteus has a reputation beyond reputeProteus has a reputation beyond reputeProteus has a reputation beyond reputeProteus has a reputation beyond reputeProteus has a reputation beyond reputeProteus has a reputation beyond reputeProteus has a reputation beyond repute
Originally Posted by Maxeffort View Post
I had a BMW R75/5 as a teenager, long before I learned how to drive trucks.
That bike taught me to blip the throttle when downshifting. It had a very clunky four speed transmission. If you didn’t blip the throttle when downshifting, it sounded as the trans would fall out. It would also make the the tire squeal on the 2-1 downshift.
I own currently a R 75/5, I do not blip the throttle, as I never blip the throttle on the Sportster.
I just use the clutch handle very slowly, in and out.
My Sportster has 125 000 kilometers, and still the factory clutch with its grenade plate.
I'm a "smooth" motorcyclist, I guess, I never race my bikes.
Just call me grand-pa
I also own a 1982 class-5 Mercedes truck, and funnily, I do blip the throttle when gearing up, the synchro-meshed gearbox is really slow on those vehicles.
Every man should have a hobby he can't afford...
