5 Cruise-Mate (Europe)
0 Brand new 2020 XL1200NS
0 Down on oil
Last Post: Billy1200
0 Vintage tires
0 I need to polarize the generator each time I start the bike
Last Post: randy3934
0 Remember these?
Last Post: bill smith
6 Happy Birthday Iree!!!
0 ‘79-81’ rear wheel offset or spacing ing issue?
0 CV carb running way rich!
0 1275 Map For Thundermax...Need Help
Last Post: XL1275
0 Sticky Ironhead trans
Last Post: Hap
0 Koso hd-01-04 2014+
0 Rear lights
Last Post: ironsquirrel
0 New to Harley - 2007 883R
Last Post: Mike1nw
0 Cancelling auto renew
Old 20th August 2019
broknluck broknluck is offline
Sportster/Buell Model: 883
broknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud of
Default Hard Struts /Weak Shocks & Torn Wires
Going to try Solid Struts in hope of prevent rubbing of tire on fender and wiring. Im not pleased with the bikes ride on our dirt roads and lanes.When the shocks flex it happens at the worst moment tearing up wiring when only hauling about 50 LBs . Im planning on some Off Road Pegs to stand up across bumps maybe a Spring Seat and Fender Brackets . Im not into cool as much as getting the darn thing to preform tasks for me.
Also found some people have installed Car Air Shocks.That may be a good way but first I need to stop the tire from ripping off wires..
Have you thought about longer shocks/springs, maybe 13" instead of the standard 11 & 1/2"?
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
Road King air shocks are a popular swap/install.
Run the wires through a piece of metal tubing. Bendable brake line or copper line.
Maxeffort's Avatar
http://xlforum.net/forums/showthread.php?t=642410
Suspension sticky index
Thankyou that covers a lot of I aint thought of..
