Last Post: tedcool
0 Xl???
0 old parts
0 Sportster drag bike
Last Post: Zip1
Last Post: robbie202
Last Post: ericfreeman
0 so it's officially ended
Last Post: FrankGS
0 '66 XLCH VM38 Conversion
0 CV Carb hesitation
Last Post: owlsplace
Last Post: Nicktater
0 Tuners
0 Morning default to odometer
0 What jets do you use?
Last Post: Thack
Last Post: Samedward
8 XLCH kicker giving me a major headache!
Last Post: Nightmare
Old 20th August 2013
JackalAR's Avatar
JackalAR JackalAR is offline
JackalAR is a glorious beacon of lightJackalAR is a glorious beacon of lightJackalAR is a glorious beacon of lightJackalAR is a glorious beacon of lightJackalAR is a glorious beacon of lightJackalAR is a glorious beacon of lightJackalAR is a glorious beacon of lightJackalAR is a glorious beacon of lightJackalAR is a glorious beacon of lightJackalAR is a glorious beacon of lightJackalAR is a glorious beacon of light
Question PC-V MAP request (1250)
Does anyone have a MAP for a 1250 10.5:1 with cams (preferrably Impact 560's) and ShortShot pipes? Thanks!
Old 30th August 2013
JackalAR's Avatar
Well, I have an established MAP to work with, so I at least want to tweak it to work well enough to get me through break-in and on the dyno.
I was thinking that it would be best to pull 7 deg. out @ WOT and adding 4-5% fuel across the board. Any suggestions? Is timing still higher than 28 or deg. under WOT?
Old 29th May 2014
JackalAR's Avatar
Actually, finding the amount of change from stock to the desired timing for the higher compression to plug into your PC-V MAP is quite simple. If anyone wants to try to save themselves a few hundred bucks, let me know and I'll help out.
