2 My 1275 Hammer Conversion..
0 su carb question
Last Post: fafcpa
Last Post: DitchTBHSMM
0 New to the Chopper Lyfe
Last Post: TUCCI
Last Post: brixtonanima
0 Too HOT to ride?
Last Post: Billy1200
0 C.O.B.B. CBD oil
Last Post: TUCCI
Last Post: SLW210
0 new to me 883
Last Post: robbie202
0 New member
Last Post: spamer80
0 Roadster CX Cafe Build
14 Mid controls??
Last Post: Nicktree1200
0 Best Street/track Camshaft for boost, help??? :)
Last Post: Jens L
0 Frame bracket
Last Post: Bwf347
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 Headlight help please
Last Post: PetesPonies
Last Post: TUCCI
0 tire changer
0 Ve tables for iron 883 with 1250 conversion
Last Post: Bikeaholic
fhilliard (79), paulmo (75), Beloved (49), Mr. Cro (49), Chopper Duke (41), Danny3nose (39)
Old 10th July 2019
Toejam503's Avatar
Air-Cooled Forever
Sportster/Buell Year #2: 1981
Default Check the Gas
Since most of the USA has been hit with storms, tornadoes, earthquakes, hurricanes, and especially flooding, this year.. I think it would be wise to ask the gas stations you patronize if they check their tanks, for water, more often.
Since gasoline sets on top of water, and the pumps draw 2"-4" off the bottom of their tanks, I'm surprised we haven't heard more complaints of "ill running" vehicles. So next time you go to "Thrifty-Pump" find out how often they "stick" their tanks. If it rains a lot, it should be everyday!
Old 11th July 2019
Hopalong48's Avatar
Hopalong48 Hopalong48 is online now
Sportster/Buell Year: 1966
Hopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to behold
Most likely the reply to that question would be,"huh?"
Sent from my SAMSUNG-SM-G891A using Tapatalk
Old 14th July 2019
the alcohol absorbs the water
Old 14th July 2019
ChinCactus's Avatar
Only to a point. When saturated the ethanol drops out of solution and collects on the bottom. Called phase separation.
Old 14th July 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
What alcohol? I don't run no stinkin' alcohol. ;P
Old 14th July 2019
Toejam503's Avatar
Air-Cooled Forever
By alcohol, I'm assuming you mean "ethanol".
. Water won't mix with gasoline, so as ChinCactus said, it separates completely from the gasoline and the gasoline sets on top of the diluted ethanol. So if your fuel pickup is on the bottom of the tank, it's only going to pull the diluted ethonal into the fuel pump or flow into the carb.
