Last Post: Gulf Coaster
0 is this a 'Hogged out' 883 head?
Last Post: duffy
0 big bore kit
0 signature pic
Last Post: Tucsonmax1
Last Post: fafcpa
Last Post: Jaykel
0 What engine oil do you use?
0 Indian FTR Sales
Last Post: duffy
Last Post: savagegarden
0 It's stalkie's Birthday!
Last Post: priell3
0 ARCH motorcycles and more
Last Post: RDHenley
0 Un-lowering my Super Low
0 A Day in the Life...
Last Post: RDHenley
0 Hack or trike?
Last Post: RDHenley
Last Post: Kbetts
0 '59 XLH - Speedo cable route
Last Post: Guidorey
buddy (66), paulrainer (66), Pedrochellie, needweknow, BunnMan (48), SolariS (43), Doc69 (39), ftptptt1234 (39), dumbmxer84 (36), nhutch40 (28), XLButler (21), Ztomasc (21)
Old 12th June 2019
LenC's Avatar
LenC LenC is offline
Sportster/Buell Model: NRHS 1250
Other Motorcycle Model: Triumph Bonneville Black
Other Motorcycle Year: '06
LenC has disabled reputation
Default Tightening clutch basket nut (left hand)
TOTAL case of brain dead today.
Trying to tighten the clutch basket nut in my '97...how the hell do I tighten that while all it does is spin the plates?
II REALLY don't want to try wedging anything in there.
What hurts worse is...I've done this a few times before!
CRS!
Old 12th June 2019
Are you talking about this:
http://sportsterpedia.com/doku.php/t...ocket_torquing
Old 12th June 2019
LenC's Avatar
Yes, the nut that holds the clutch basket on.
I just ordered a tool from Motion Pro that looks like grip pliers with long jaws and bent in a short leg "L" at the end.
That grips the center hub to keep from spinning as you tighten.
I have both HD and Clymer service manuals and neither addresses this.
Only the engine nut.
Old 13th June 2019
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
4" brass door hinge like in the photo in the post IXL2Relax just gave you.
Old 13th June 2019
LenC's Avatar
That won't work.
You can't tighten this nut with the pressure plate in the way which is the only thing
that would keep the center hub from turning.
Old 13th June 2019
Do you have a Factory Manual???
When removing the primary drive assembly (Engine Sprocket, Primary Chain & Clutch Sprocket), the clutch basket is intact - ONLY the release mechanism is removed to gain access to the Sprocket Nut... Using the brass hinge to wedge between the Engine Sprocket & the Clutch Sprocket will keep the fully assembled clutch basket from rotating...
When re-installing, the fully assembled clutch basket (with clutch plates & pressure plate in place) ONLY has the release mechanism removed in order to have access to the Clutch Sprocket Nut...
The Engine Sprocket, Primary Chain & Clutch Sprocket are removed and/or re-installed as a 3-piece assembly...
??? Now ??? If you still have a question, please post a picture and explain in clear and concise language, what you are trying to do...
Old 13th June 2019
kiwicafesporty's Avatar
kiwicafesporty kiwicafesporty is offline
Other Motorcycle Model: MV Agusta
kiwicafesporty has much to be proud ofkiwicafesporty has much to be proud ofkiwicafesporty has much to be proud ofkiwicafesporty has much to be proud ofkiwicafesporty has much to be proud ofkiwicafesporty has much to be proud ofkiwicafesporty has much to be proud ofkiwicafesporty has much to be proud ofkiwicafesporty has much to be proud ofkiwicafesporty has much to be proud ofkiwicafesporty has much to be proud of
Been a while since I was in there. But maybe he has removed the clutch basket and needs to tighten the big nut that holds the whole assembly onto the gearbox shaft.
Old 13th June 2019
LenC's Avatar
Kiwi's got it.
That's precisely the situation.
Old 13th June 2019
LenC's Avatar
It would be a lot simpler if you would direct me to the page in the manual that you're quoting.
As I clearly stated previously, I have both HD and Clymer manuals.
I also stated it's the nut that holds the clutch basket on.
Regardless, just point me to the correct page and I'll be most appreciative.
I do appreciate your efforts.
Old 13th June 2019
ReddTigger's Avatar
you're talking about the nut that holds the rear sprocket on in the following picture. correct ??
States I've Ridden in
71.3 hp 70.8 tq
