0 Question for RB racing exhaust guys/gals
0 Wet sumping?
Last Post: WI_duker
0 Exhaust - Generic questions
Last Post: canoli
0 Innovative motorsports 3918
0 .551 Cams in an EFI 1200
Last Post: EL in NH
Last Post: jollyroger83
Last Post: DBH
0 Battery reversed, bike dead
Last Post: rugger2
0 Intermittent Ignition Problem On 1992
0 Bike lost power,back fired and stalled
0 Sundowner seat positioning
0 Grounded
0 Monday 17th June 2019: Marshwood Vale
0 WTF Happened
Last Post: Clevspeed
0 Motorcyclist struck by lightning!
0 Primary chain noise. Normal?
Last Post: xena
0 Internal Exhaust Rust Prevention
Last Post: T. Clark
0 O ring vs rubber band intake seals
0 A Mad Lad on a Blast
Last Post: Crash7557
Last Post: Hornsmith
0 74 XLCH - a revival
0 Florida Woman Plows Through Crowd At Harley-Davidson Concert
Last Post: Calcustom
0 brake line length for higher bars?
longhair (65), Ozarkster (62), Monstermile (50), killswitch (50), yu69lorenzo (50), ChrisAF (49), Ingemar (48), Omega (44), bald_bueller (43), BEHIND BARS (42)
Old 4 Days Ago
Gone_Shootin Gone_Shootin is offline
Gone_Shootin is a splendid one to beholdGone_Shootin is a splendid one to beholdGone_Shootin is a splendid one to beholdGone_Shootin is a splendid one to beholdGone_Shootin is a splendid one to beholdGone_Shootin is a splendid one to beholdGone_Shootin is a splendid one to beholdGone_Shootin is a splendid one to beholdGone_Shootin is a splendid one to beholdGone_Shootin is a splendid one to beholdGone_Shootin is a splendid one to behold
Default Flowster?
The other day I picked up a '72 Ironhead project bike. The primary cover says "Flowster" on it. He said he thought it might be an oddball variant, but want sure because he couldn't find any info. Somebody also suggested that it may be an aftermarket cover or decal.
Anybody here know? Thanks in advance!
And sorry of the pics are huge. I'm still figuring out how to shrink them on my phone.
Old 4 Days Ago
Air-Cooled Forever
When you go into imgur.com click on the pic,, you want to hit "edit pic'' at the bottom right corner,, go up to the size box (upper right) ,,change the left number to 1000 and the right number will change auto,, click save, then go back to images ,,click on same pic,, hit "bbcode'' then go to this message box and click paste.
Old 4 Days Ago
Highly-Dangerous's Avatar
Sportster/Buell Model: XL 883
Can you make these pics bigger?
"Maintenance is as much art as it is science"
Old 4 Days Ago
Dual plugs, odd markings on cylinder bases and a bike named named FLOWSTER. The mind races...
Merely dying will not get your name removed from the enemies list!
Old 4 Days Ago
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Iron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant future
Looks like heads may have some port work. Check the flywheel #'s through the timing hole.
Any chance prev owner had Progressive insurance???
Old 4 Days Ago
o.e.m. barrels weren't marked front and rear.
Old 4 Days Ago
Thanks for the tip.
And thanks everybody. One of the previous owners built the piss out of this engine. I guess when it was running it had a pretty healthy lope and had gobs of power. I didn't know about the cylinders being aftermarket. I wouldn't be surprised if he figured out how to big bore it. The guy who built it is a local guy that's known for hot rodding Harleys. It's been sitting for 8 years though, so it does need taken apart and looked over. I am curious why it was robbed of so many parts over the years, though.
As for the cover, I'll probably sit it aside and hang it on the wall or something. It's sort of folk art at the least...make for conversation, ect.
Old 3 Days Ago
Originally Posted by Gone_Shootin View Post
Thanks for the tip.
Have you talked to him??
Old 3 Days Ago
Scott Scott is offline
Sportster/Buell Year: 1981
Other Motorcycle Year: 2002
Scott has much to be proud ofScott has much to be proud ofScott has much to be proud ofScott has much to be proud ofScott has much to be proud ofScott has much to be proud ofScott has much to be proud ofScott has much to be proud ofScott has much to be proud ofScott has much to be proud ofScott has much to be proud of
What’s that vertical rod coming out from the primary cover?
Old 3 Days Ago
spacecoast spacecoast is offline
Sportster/Buell Model: 883
Sportster/Buell Year: 1989
spacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant future
I think it's an illusion sCOTT. I think it's a plug wire.
When it comes to FLOW only one man truly comes to mind.........
