Keep & Kill
Stairman, toby61, Greywolf (73), federico (70), Big D (69), robin82732 (58), jbd777 (52), Steve3888 (50), RIORoosen (48), NXC1978 (44), JeffsJeep04 (37), Matt.loup.t |
7th August 2013
Posts: 19 Sportster/Buell Model: XL 883 Sportster/Buell Year: 2000
Bent forward control... peg?
Dumped my 2000 sportster 883 std. in the rain last friday. I bent the "peg" on the left side shifter on my forward controls. I don't want to spend another couple hundred on a whole new control set when all I need is this swivel piece that has the peg that the lever attaches to.
My question:
Can I just replace this "peg" piece of my forward controls?
If I can replace it, what would it be called? Is there a part number?
These forwards I have are the general chrome aftermarket forwards you see everywhere on ebay for 91-03 sportsters.
http://www.ebay.com/sch/i.html?_odkw...91-03&_sacat=0
I took the shifter lever off and took a couple photo's of what I'm talking about. I tried bending it back with a large spanner but could not get the right leverage. Might have to mcgyver something together to help me with that.
Any ideas would be a great help
7th August 2013
Posts: 2,847 Sportster/Buell Model: XL1200c Sportster/Buell Year: 2006
That looks like the kit I put on OrlandoDrivers '97.
eBay has the whole kit for about $200. Now instead I would start hitting up all the swap meets and flea markets and find a used one cheap.
But for now you could remove the bent arm from the sleeve its in and put the bent part in a vise and then with leverage grab the longer end. Heat may need to be applied. Just protect the splines.
7th August 2013
Posts: 2,583 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2009 Sportster/Buell Model #2: XL1200L Sportster/Buell Year #2: 2009
Yeah, what he said. Only heat SHOULD be applied. Make it easier to straighten & save the steel from stress cracking.
7th August 2013
Thanks guys!
I'm going to give it a shot tomorrow when I get some time in the garage.
A few more questions.
What would you suggest I apply the heat with? Would a blow torch be suitable?
Should I get it red hot? or is that something I should avoid?
Thanks again for the tips. Could save me a couple hundred $$$ , or a few twofours!
