2 Weeks Ago
Posts: 31 Sportster/Buell Model: XLH 1100 Sportster/Buell Year: 1986
After checking this out a bit further I found they had wired the neutral switch to this gen light....
1986 XLH 1100
2 Weeks Ago
Posts: 6,454 Sportster/Buell Model: XL77.2R Sportster/Buell Year: 2006
Stay on might mean your neutral wire is shorted.
2 Weeks Ago
I think you misunderstood, if you had read the thread you would see that someone put and earlier sporty head light shroud on this with the oil/gen light mounted on them. what they did as they wired the neutral switch to the gen light. I the switch is fine I discovered that when I put into gear the gen light goes out. So it is a matter of disconnecting the wire from the gen light to the neutral light mounted on the instrument cluster bracket....
