Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Transmission, Clutch, Primary & Secondary Drive
0 Bike lost power,back fired and stalled
0 Battery reversed, bike dead
Last Post: rugger2
Last Post: motorend
0 Sundowner seat positioning
0 Grounded
0 Monday 17th June 2019: Marshwood Vale
0 WTF Happened
Last Post: Clevspeed
0 Motorcyclist struck by lightning!
0 Primary chain noise. Normal?
Last Post: xena
0 Wet sumping?
Last Post: WI_duker
0 Internal Exhaust Rust Prevention
Last Post: T. Clark
0 O ring vs rubber band intake seals
0 Question for RB racing exhaust guys/gals
Last Post: spamer80
0 A Mad Lad on a Blast
Last Post: Crash7557
Last Post: Hornsmith
0 74 XLCH - a revival
0 Florida Woman Plows Through Crowd At Harley-Davidson Concert
Last Post: Calcustom
0 brake line length for higher bars?
0 Brake pad rivet tool (1977)
0 Intermittent Ignition Problem On 1992
Last Post: ken883/1200
0 Cool Ironheads meetup last week w pics!
Last Post: frogg_nutts
0 Front brake is terrible
Last Post: Four Speed
longhair (65), Ozarkster (62), Monstermile (50), killswitch (50), yu69lorenzo (50), ChrisAF (49), Ingemar (48), Omega (44), bald_bueller (43), BEHIND BARS (42)
Old 21st May 2014
Sewerat's Avatar
Sewerat Sewerat is offline
Sportster/Buell Model: X1 lightening
Other Motorcycle Model: Yamaha wr250r
Other Motorcycle Year: 2009
Sewerat is an unknown quantity at this point
Default Tranny upgrade
Ok so I just picked up my new to me buell. This was my first ever rode on street bike so it has some memories for me. The issue with it is that it had a bent shifter fork, I think stuck in 3 it has all been torn apart and the dog seems to be ok just one fork outta shape. Replacing the main bearing , forks, gaskets anything else. Or is there a possible trans upgrade I should look into before I get it done.
Old 29th May 2014
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Folkie
South East England Riders
Old 19th June 2014
Phelan's Avatar
Phelan Phelan is offline
Sportster/Buell Model: EBR 1190 SX
Phelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud of
Baker shift drum or drill the stock one to replace the detent plate retaining ring with a screw. Other than that, you can get a billet trap door or a Baker 6 speed that comes with all of the above, but you're talking serious cash in those cases. Even the Baker smooth shift kit is like $300.
BTW the reason to replace the retaining ring with a screw is because there is a REASON the stock detent plate is called a grenade plate. The ring breaks very easily, including on my XL1200S when it had 15,000 miles.
Love is the never-ending act of forgiveness - Peter Ustinov
Old 20th June 2014
Sewerat's Avatar
Any links to the retaing ring? For instructions
Old 20th June 2014
Phelan's Avatar
http://xlforum.net/forums/s...d.php?t=198227
http://xlforum.net/forums/s...d.php?t=494406
http://www.badweatherbikers.com/buel...tml?1275691561
Old 20th June 2014
also when you take off the detent make sure to tap in all the pins behind it as they tend to wander out which cause the trans to not shift properly.
Old 20th June 2014
Sewerat's Avatar
The bike is already in pieces. Bucket of parts for me to reassemble. Still need to get replacement parts for it. New shifter forks and seals before I start re assembly. From what I was told it got stuck in 3rd and bent that fork, shifter drum appears to not have been effected but the one fork is bent for sure. I will be pricing out parts this weekend at my local dealership. I'm expecting about $500
