Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Transmission, Clutch, Primary & Secondary Drive
0 Arbor press for crankshaft
Last Post: Campsurf
0 Hello from San Clemente, California USA
Last Post: Wilkinson949
0 Seized Oil Pump
0 Fuel Pump Problems
0 Rubbermount shocks on a rigid mount?
Last Post: DirtyJay
0 HD Solo Seat and Pillion '86-'03 $130
0 my build in my apartment
Last Post: rickthrash99
0 Finding a new doctor...
Last Post: oupa
0 ***DK Custom-LIMITED TIME Sweetheart Deals-Save 10% On Select Products***
5 What's Your Temp Today
Last Post: Kbetts
10 What's your Personal Tech
0 Motorcycle cafe suggestions
Last Post: oupa
0 compression problems
0 12" or 14"? (Apehangers)
Last Post: oupa
0 Welding on Hardtail
Last Post: Holytown
0 Remove stock kickstand mount from frame
Last Post: Holytown
0 Forum problems???
Last Post: oupa
0 Hello from Belgium
Last Post: old dog
Last Post: Akdawg
beertp (64), Jcolleyoh (64)
Old 12th August 2015
Boggs Boggs is offline
Sportster/Buell Model: S1 lightining
Boggs is an unknown quantity at this point
Default S1 clutch pressure plate
Hi, I have a 1998 s1 Lightning. Replaced a broken clutch cable the other day and rode the bike home. On the way it appeared as if the cable broke again. Turns out that the lip on the pressure plate for the retaining ring that holds the throw out bearing broke. Any body ever hear of this. What could be the cause.
