0 New Gas Tank or Cat Litter Jug.
Last Post: broknluck
0 Finding Combo Rectifier / Regulator
0 RIP Peter Fonda (02/23/1940 – 08/16/2019)
0 OMFG This is how far the UK has fallen
0 Branch O'Keefe heads (with photos)
Last Post: Serious Blac
0 Helmets Please...
Last Post: Traxx
0 Starter under load
0 It's xena's Birthday!
0 A Day in the Life...
Last Post: William63
0 Got my 77 running. How does it sound?
Last Post: Yakcm2
0 Solenoid rebuild drained battery
Last Post: mikam123
0 Use Force Sportster Exhaust
0 What oil and filter to use in 2005 1200c
0 Timing
0 Score! CS Turnouts
Last Post: Joe_jeep
5 What is the correct compression you should see in an ironhead?
0 Lifting a low
Last Post: Joe_jeep
BobH (65), jcrow (65), release (64), Iron Joker (59), rickschad (56), mickes (55), indyrednek (55), jarhead08, koidac (43)
  #731
Old 2 Days Ago
one hp equals 746 watts.
Old 21 Hours Ago
XLF member Rubine went to great lengths to move the scavenging from the rear of the sump to the front of the sump by way of manipulating flywheel force on the oil's direction.
Apparently he believes the wheels play a big part in pushing oil for scavenging.
http://sportsterpedia.com/doku.php/techtalk:refil05g
Old 19 Hours Ago
Sportster/Buell Year: 1988
The EPA data is linked on here: https://www.epa.gov/compliance-and-f...-and-equipment
I have the 2015 download that quotes power for the 883 and 1200 as 30 and 40 KW respectively. The current download has it at 40 and 50 KW respectively.
Maybe the 2015 figures were a mistake, otherwise HD has regained about 25% more power since 2015.
Old 12 Hours Ago
Thanks for the link.
This is from the 2020 Sportster thread.
None of this electric mess seems appealing.
Originally Posted by jzink0883 View Post
The 2020 H-D models are listed on the motorcycle-compliance spreadsheet at the EPA website: https://www.epa.gov/sites/production...6-present.xlsx
Doesn’t look like anything has changed in the engine for 2020. Same displacements. Still 2 valves per cylinder. Still 5-speed trans. Same power ratings as in 2019.
I eliminated some columns and grabbed the screenshot of the 2020 Sportster information.
Originally Posted by Maxeffort View Post
It’s in KW. Multiply KW x 1.341
883 has 53.6 HP
1200 has 67 HP
