0 Big bore Stroker problem
6 brake caliper spacing
Last Post: swampig
0 Fyi
0 Bike wobble question
0 One More Ohio Meet & Eat?
0 New oil tank
0 Perfect riding music
Last Post: seajay
0 Gear Spacing Question
0 1969 Shifter shaft bushing
Last Post: sleighcrane
0 WTS: Forward Controls 2004-13
0 It's Glamazon's Birthday!
Last Post: XL1275
0 too much oil in primary
0 Oil leaking
Last Post: tizard
0 Rear cylinder exhaust nuts
Last Post: XL1275
0 Thread pitch for 91 front engine mount bolts.
0 stumble
0 Done for now (no really)
Last Post: Eric Von Zipper
5 Favourite grips?
0 What Carb
Last Post: salmanmr
Last Post: jcro61
backfire, carb adjustment, carb fart, tuning
Old 7th February 2012
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
a factory 1200 is a 170 and an 883 is 160 main jets i think. I had a 175 in a 93 sporty with buell heads and cams ect...you dont need that big of a main jet.
madnss's Avatar
that thing should run fairly good with any size damn jet....like the other guy said...float..or you messed something up in your rebuild...or igintion is bad....thats my guess and im sticking with it..lol
Make sure all your coil...plug...and what not connections are good too
smay23 smay23 is offline
Sportster/Buell Model: 883 XLC
smay23 is an unknown quantity at this point
Merc
I have started over if you will by putting the stock jet sizes (42 and 160) back in and stepped away for a breather for now. I have taken rather comprehensive notes on all the things going on here so I don’t lose track of the way things progress be them good or bad. It is easy to get “lost” when making tuning adjustments and I am doing my best to finger this out! But I do agree with you when you said try to go back to “normal” and see what happens there.
Rooster
Madnss
I agree with you brother… any jet should iron this problem out. As far as the float level is concerned, I checked the adjustment in accordance with the factory manual to make sure that it was within limits, and it was. I think when I get in tonight I am going to investigate the faulty ignition module the bike sat for several months without running and sitting is WAY worse for any piece of equipment. I think with a stage one kit (since I am moving more air) a 45 jet and a 165 jet should do just fine here. Since I am running a stock air box and mufflers with baffles installed, anything over that would be too rich!
Rooster
rocketmangb's Avatar
No mention of the idle mix screw ?
A 45 pilot should flow about 9 % more fuel than a 42
What needle is in there ?
Lets check the slide diaphragm too !
Make sure we have vacuum to the VEOS so the timing will advance and retard when it should
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Rocketmangb
I put the stock jets (42 and 160) back in there to start from scratch. The slide diaphragm is good to go, I held it up to a light to inspect it and saw no tears or pin holes in it. I also replaced the three vacuum lines hidden under the tank because they were dry rotted pretty bad (got “rubber dust” on my hands when I touched them!). I have heard mixed reviews and sorted advice when it comes to messing with the idle mixture screw. Some say adjust and others say don’t. I know that these bikes run lean from the factory due to EPA and emissions standards. I fear the unknown here brother. I know my way around a car carburetor OK but am still learning on a CV carburetor. Folks tell me if it is lean just step up the jets and call it a day and DO NOT mess with the IMS! What do you think?
Rooster
madnss's Avatar
Madnss
Got new vacuum lines installed and in the propper routing and location. I wonder if the VOES took a dump?!? I am going to put a spark analyser on it in the morning to check the ignition module. Sure hope that ain't it CHA-CHING! LOL
Rooster
madnss's Avatar
A factory Cone ignition is about 70 bones and voes about 45. Good luck!!!
Madnss
Thanks for the info buddy and in case you are curious about the outcome check back in a few days to see the result!
Rooster
