0 Ceramic Coating My Paint
0 Hello from New York
Last Post: oreocat1
0 Hi from Calgary
Last Post: oreocat1
0 crank case breather
Last Post: Jollly Rogers
0 Ride Report for the 2019 Void rally
0 Flame's New 1989
0 1960 XLCH in the UK
Last Post: soundnav
0 It’s Glamazon’s Birthday!
0 Bike sold leaving forum
0 570's or 536, 560's @10:1 Compression
Last Post: Bikeaholic
0 Battery/regualtor/charging strange problem
0 Spokes or Mags
Last Post: 51 New West
0 40mm CV vs. S&S Super E for Draw thought Turbo!
4 The no-debate OIL POLL
Last Post: Boil1337
0 Rico Lutsey aka Rico 05R
Last Post: rubine
0 Carburetor opinions
0 Mid West Meet & Greet
Last Post: MatHormell
jdhickm (84), Chip (71), Chief4x4 (69), willyobiker (67), CBryant (66), XLCH69 (63), sage (60), Butch (60), VettesRule (57), jerseyjeff (57), TheExecutioner (54), SalTheWop (54), manic_mechanic, pauldmedic16 (45), BluegrassXL (41), Superman
Zari Zari is offline
Sportster/Buell Model: Xlh 1000
Sportster/Buell Year: 1982
Zari is an unknown quantity at this point
Red face Ss carburetor
There is freedom between. The rubber band and. Manifold is correct???
l get backfire
From my ExperienceI Experience knows that there must be little. tight
doodah man's Avatar
The carb manifold doesn’t touch the head directly - no metal to metal contact. The connection is made by the rubber band and the clamp. If you over-tighten the clamp it can leak air in and cause backfiring.
Sportster/Buell Year: 1969
Other Motorcycle Model: 04 Ironhorse Outlaw
RicThompson is an unknown quantity at this point
Please be aware that if your engine has an intake manifold leak and you continue to ride it you run the risk of leaning out and overheating causing significant damage. If you are unsure take it to your local repair shop.
A small sprinkle of carb cleaner on the joint with the motor idling will show a leak.
