Last Post: Bikeaholic
3 Shaky Dave Recovery
0 spark plug wire ohms
Last Post: Kbetts
0 Finally Got the Kinks Out
Last Post: Proteus
0 2.18 Gearing Ratio For 5 Spd 1200??
Last Post: vagrant318
0 Getting ready to try firing it up after a year long rebuid
0 Head bolts and conversion
0 Alarm Time Out?
Last Post: brixtonanima
0 Finding an accessory power source
0 1972 XLH question
Last Post: 1Scooter
Last Post: marksfatboy
0 Rocker cover torx
0 FS: Forward Controls (2004 - 2013 Sportster)
Last Post: wrkdWS6
0 my recent ebay purchase
0 Who Runs Turn Signals?
Last Post: Tincan
0 '86 1100 basket build
0 Stretched Swingarm
Last Post: Racepres
0 cleaning method for cases
0 Is static timing enough?
Last Post: ccmman
0 Changing engine oil
0 su carb question
0 Touring on a Hugger
Old 11th January 2020
Folkie Folkie is offline
Quality sockets don't slip if you use the correct size. Glad you found something that you like.
Sportster/Buell Year #2: 2005
Other Motorcycle Year: 2018
stikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud of
They are both good sets but i do prefer hexagon sockets i have had the Halfords set a good few years the lidl stye only about a year
rejeanprimeau's Avatar
People wrongfully use the 12 side box on six side bolt and complain to round the head???
Each tool for it proper use.
My first tools were in a box given to me by my dad over 55 years ago. He always said to never by cheap tools because you will never lose them and you will rarely break them. I still have that original box of tools plus many, many more. I've never bought cheap tools and I only lend them to someone I trust. When I finish a job, I put them back in their designated place. Dad also said, "A place for everything, everything in its place."
Just like shoes, in the long run expensive tools are less expensive than the cheap ones.
I have no experience of Lidl tools whatsoever. With the Halfords tools, it is particularly the Professional range that I recommend. There are, of course, many other good quality ranges of tools. I have got several items from the Draper Professional range, particularly large sockets for rear axles, and such, where I couldn't easily find them in other makes. Snap-On are always good, and sometimes you can't find what you want anywhere else. There are many other quality makes, but mostly you can only find them online.
I have on occasion bought tools from the States, when I couldn't find what I wanted in the UK at all. Eg: lock ring pliers (not circlip pliers). And I wanted a deep, thin wall, 9/16" six point socket, for the stock breather bolts. In this case a six point socket is necessary, as there is very little engagement of the socket with the flats of the 'bolt', and in this case a 12 point socket is liable to slip. The only place I could find such a socket (in a reasonable quality) was from the US; so I did (Tekton).
I mentioned Halfords particularly, because almost everyone must have a Halfords branch not too far away, and it's easy to find out where the branches are. Anywhere else is going to be harder to find, and it's going to be different for different people.
