0 Screw Loose's Repairs
Last Post: cotton1
0 Best Tires to get 2017
Last Post: cotton1
0 check my chain?
Last Post: lmarshall73
0 Oil Pump upgrade
Last Post: hotrodbiker
Last Post: jordan1200
0 1990 Sportster. Something is pulling voltage from battery??
Last Post: Four Speed
0 Bob from Appleton WI
Last Post: VaFish
0 New Hammer Impact Air Intake Powder Coated
Last Post: Outtakes
0 first change, very little oil
0 As far as maintenance goes...Cycle Electric or Alternator?
Last Post: Silky Johnson
0 Who Runs Turn Signals?
Last Post: vagrant318
0 Free to a Good Home (pay $8 shipping only):2014 FSM, used
0 Removing powder coat?
Last Post: Oli1200
0 883 Sportster in Baja
Last Post: VaFish
0 Shotgun Porn
Last Post: sportysrock
0 Passenger floorboards and sissy bar questions
Last Post: chris16371
0 THE Trainspotting Thread
0 1962 XLCH Front Wheel WTB
Last Post: Jaykel
0 Stuck in fist after a spill
Last Post: amfxlh
0 Fact or Fiction - HP Claims
Last Post: jcro61
Last Post: wongjohnson
4 Cross Country Prep
stevervp, philvet (75), outlawreb (63), rabes56 (62), Bigmatt (60), Beaker666 (54), hippiemwc (54), wumm883c (52), 2wheeltodd (51), israel (46), XRWeasel (44), Stitch (41), Dekooy (35), Titaniumrust (35), Ameri-Deutsch (34)
Old 14th September 2017
jimmyess333's Avatar
jimmyess333 jimmyess333 is offline
Sportster/Buell Model: none
Sportster/Buell Year: 0
jimmyess333 is a name known to alljimmyess333 is a name known to alljimmyess333 is a name known to alljimmyess333 is a name known to alljimmyess333 is a name known to alljimmyess333 is a name known to alljimmyess333 is a name known to alljimmyess333 is a name known to alljimmyess333 is a name known to alljimmyess333 is a name known to alljimmyess333 is a name known to all
Default Can I have a standard oil pump converted to high volume?
There is no high volume oil pump available for the engine I want to install one on (1988-2001 Chrysler 3.0 V6).
Is there a service that converts stock oil pumps to high volume?
sportsterdoc's Avatar
Other Motorcycle Model: Honda CB1100
Other Motorcycle Year: 2014
Is the 3.0 made by Mitsubishi for Chrysler?
What is current volume?
What is your target volume?
Yes, that's the engine.
The engine has high miles but runs great and doesn't burn oil.
I put rebuilt heads on it last year because it had a bad a bad valve, bad valve seals, and a couple of bad lifters. I also cleaned out all the carbon while I was in there.
The oil pressure is at 4psi idling when the engine is hot.
I feel like it should be closer to 10psi...it was like this before the headwork and it's still the same. I think this might have contributed to the bad lifters.
It's a little cooler today. I'm getting a fluctuation of 6-7psi at idle when hot.
I'm thinking the crank bearings have some wear and that's where I'm losing some psi.
Old 15th September 2017
Sorry for the delay in response, but just got back from Death Valley.
Maybe you may want a new oil pump, but I have no info on a high output unit.
I was thinking of that too, maybe a new stock pump and pickup if I can't find a high volume.
