Uquackmeup (70), Ralphthe3rd (64), BigJim (62), DollarBil (61), DM-SC (59), nickstoyz (57), HD CRAZY (55), Roadkill (52), Ekalb2000 (50), someday808 (46), bob.cremeans (44) |
26th November 2021
Posts: 27 Sportster/Buell Model: Ironhead XLCH Sportster/Buell Year: 1976
Ironhead engine problem?
Hey guys I have a 76 xlch, I was having a problem where the engine was stuttering when I would open the throttle, it wouldn’t happen all the time and some days were better than others. I first thought carb, since the carb would also spill a lot of gas on kick start(sometimes a lot other times not so much). I rebuilt the carb, noticed that the fuel bowl nozzle wasn’t spraying gas tried to clean, eventually I bought a new fuel bowl( it’s a bendix 38mm carb) and put it back together. At first it was difficult to start, but I messed around with the jet settings and eventually I got it going. It rode pretty good for about two days, today I took it out, I noticed it was backfiring and stuttering a bit. I tried to take off at a red light and it stuttered to go and turned off. I tried to turn it back on and was successful, but when I went to take off it kept stalling. Eventually It didn’t turn back on and I ended up walking about 2 miles back home. Any ideas or suggestions?
27th November 2021
Posts: 678 Sportster/Buell Model: XLCH Sportster/Buell Year: 1972
Are all your grounds good?
27th November 2021
Not sure honestly. What should I look for?
27th November 2021
Posts: 665 Sportster/Buell Model: custom Sportster/Buell Year: na
crap in your fuel system, start with your tank, lines ,filter then your carb again
27th November 2021
Posts: 11,292 Sportster/Buell Model: XLCH Sportster/Buell Year: 1975
Still running points? Make sure your point gap hasn’t closed up, and make sure you don’t have a broken advance spring.
27th November 2021
Posts: 750 Sportster/Buell Model: XLCH Sportster/Buell Year: 1971 Sportster/Buell Model #2: 1973 HD/Aermacchi TX125 Other Motorcycle Model: 1988 BMW K75
+1
These are classic ignition system issues associated with points, condenser and advance.
27th November 2021
Yeah I’m running points. I’ll have to look into that, I do notice that there is also crap in the tank, so I’ll have to take care of that as well.
27th November 2021
I did notice there is some stuff in the tank, but fuel is flowing through lines to carb
27th November 2021
Posts: 450 Sportster/Buell Model: XLCH Sportster/Buell Year: '68 Sportster/Buell Model #2: FXR Sportster/Buell Year #2: '89 Other Motorcycle Model: R50/5 Other Motorcycle Year: '73
Fuel tank venting OK?
27th November 2021
I believe so, fuel seems to be flowing to the carb, there’s a good amount of fuel in the in line filter
Hybrid Mode
