Uquackmeup (70), Ralphthe3rd (64), BigJim (62), DollarBil (61), DM-SC (59), nickstoyz (57), HD CRAZY (55), Roadkill (52), Ekalb2000 (50), someday808 (46), bob.cremeans (44) |
28th November 2021
Posts: 665 Sportster/Buell Model: custom Sportster/Buell Year: na
I have run an inline filter for years with no problem, there should be nothing floating in tank
28th November 2021
Posts: 8,112 Sportster/Buell Model: XLB, XLCH, Sporton Sportster/Buell Year: 1962 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1966 Other Motorcycle Model: XLCH (Another one) Other Motorcycle Year: 1966
Originally Posted by rocketnorton
what is the "molasses trick"?
never heard of that one
One of the best ways I know to clean rust and muck out of a gas tank.
1/3 molasses 2/3rds hot water (helps dilute the molasses).
I use a whole jar of molasses. Mix it up, pir it in. Turn the tank over and slosh the mixture around.
Now this does take time. Here we're talking days, not hours or minutes.
Every time you go near the tank turn it over and slosh it around. The more often the better I guess but it's not critical as far as I can tell.
Might take a eek. In any case, when your done your back to bare, shiny steel. The molasses eats rust. Seriously. Any rust.
Google rust and molasses and you'll see the results.
I've never found anything that's better.
28th November 2021
Posts: 242 Sportster/Buell Model: xlch Sportster/Buell Year: 1972 Other Motorcycle Model: homebilt fxr Other Motorcycle Year: 80+
^^^ sounds good
ive used vinegar, but it will flash rust when dumped, gotta get a fuel/oil mix in it right after dump
pete
28th November 2021
Posts: 27 Sportster/Buell Model: Ironhead XLCH Sportster/Buell Year: 1976
Originally Posted by Ferrous Head
OK. What did the shop do to the bike in 8 months ?
You need to learn to do things systematically. Just guessing and doing things randomly is not a great idea. You may "play" with things you don't need to and possibly cause further problems.
I always begin with a compression test. Compression gauges are cheap and not hard to use.
They will tell you a lot about your engine.
Your obviously familiar with taking the carb off so substitution will save a lot of time and effort when it comes to carb problems. $49 on ePray will get you a new fake S&S Super E jetted for your engine. A cheap tool.
Before you put a new carb on though you do need to make sure your tank, tap and lines are clean. If the tank is rusty inside take the time to do the molasses trick.
After this if the problem is still there it's going to be ignition.
I took it in because the battery wasn’t charging and I was unable to shift past 1st, the only reason it took so long was because the shop I took it to was only open 1 day a week cause of covid, it was a real headache. I got the bike last October so just been trying to get everything going, little things here and there. I do need to clean out the tank, there are chunks of what looks like rust floating in there. There’s much I need to learn, appreciate the advice
28th November 2021
Originally Posted by doodah man
But still, if this is happening in gear your clutch could be dragging a bit. It’s life with a “wet” clutch. There’s a fine line between adjusted just right and dragging. If it doesn’t act like it wants to die in neutral but does in gear, revisit your clutch adjustment. What weight oil is in your primary?
Right now I’m using HD SAE 50, but I’m thinking of doing an oil change soon. Would you suggest something different. I’m using it for both engine and transmission.
28th November 2021
If you have anything at all floating in there it's a good chance the carb is now full of it.
28th November 2021
Gonna have to clean out the tank, check pushrods and points. A lot of work ahead of me before I can ride again lol
28th November 2021
Thanks for the advice, I definitely have a lot to learn. How long would you suggest to do the molasses trick? Also any suggestions and what to do with the full tank of gas that’s in there?
28th November 2021
Rider Of The Iron Steed
Posts: 32,806 Sportster/Buell Model: XLH Sportster/Buell Year: 1978
Originally Posted by Congojack
... How long would you suggest to do the molasses trick?...
https://www.christinedemerchant.com/...t-removal.html
I would take the used gasoline to a recycle depot.
28th November 2021
Posts: 11,292 Sportster/Buell Model: XLCH Sportster/Buell Year: 1975
You might benefit from a 20w50 in colder weather - so that really depends on the outside temps where you live. I use Castrol gtx 20/50 simply because it’s easy to get.
